Environment:
Windows 11 x64
Connect IQ SDK 9.2.0 build 2026-06-09-92a1605b2
Target: fenix8solar51mm / tactix8solarelite51mm
Device Connect IQ version: 6.0.2
Java: Temurin 21.0.11+10
Connect IQ SDK 9.2.0 compiler2 fails while compiling independent minimal fixtures for fenix8solar51mm.
Observed failures:
1. Valid private and public variable declarations are rejected in ProgramVisitor.buildDeclarationFlags.
2. A fixture without visibility modifiers or a source-level bitwise OR operation fails on a generated bitor operation in HasCheckVisitor.visitInvolatileOp.
3. SDK 9.1.0 separately fails while processing the current fenix8solar51mm device metadata because sizeKey is null.
No PRG file is produced.
Expected behavior:
Valid declarations should compile, compiler-generated operations should be accepted by the compiler pipeline, and supported device metadata should be parsed normally.
Please identify a corrected SDK/compiler build or an officially supported workaround. Detailed redacted logs, reproduction material and hashes are available and can be provided in a follow-up attachment.
Brandon.ConnectIQ
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
Brandon.ConnectIQ
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
