Acknowledged
Connect IQ SDK 7.4.3 Oauth2 malforms urls on Android
When using the authenticate oauth2 API, the url sent to the default browser by the Connect IQ app is malformed on Android devices.
The url should look like https://requesturl?parameter1=xxxxx&parameter2=yyy etc
But instead it produces https://requesturl&parameter1=xxxxx&parameter=yyy
The url is correctly formed on iPhone devices. Suggesting the bug is in the Android Connect IQ app
Parents
  • > Oh, I've found a way round it by adding ?android=1 to the auth url, if the user selects Google Android as the phone type in the app settings.
    Do you mean you make a call like this for android:
    Auth.makeOAuthRequest(
       "https :// requesturl?android=1", // requestUrl
       { // requestParams
          "param1" => "A",
          "param2" => "B"
    And it turns into this:
    requesturl?android=1&param1=A&param2=B
    If so, why can't you just modify this slightly to add another dummy parameter, but in the params dictionary, so it could work for both android and iphone?
       "https :// requesturl?dontcare=1", // requestUrl
       { // requestParams
          "dontcare" => 1,
          "param1" => "A",
          "param2" => "B"
    On android I think this should be:
    requesturl?dontcare=1&dontcare=1&param1=A&param2=B
    Here the server will see two dontcare keys, each with a value of 1.
    On iphone I think this will be:
    requesturl?dontcare=1?dontcare=1&param1=A&param2=B
    Here the server will see one dontcare key, with a value of "1?dontcare=1"
    Sorry if I'm missing something here.
Comment
       { // requestParams
          "param1" => "A",
          "param2" => "B"
       { // requestParams
          "dontcare" => 1,
          "param1" => "A",
          "param2" => "B"
Children
