Ticket Created
WERETECH-12052
Conflict/race between makeWebRequest and Storage.setValue called from onUpdate on a watchface.
Hi, I was able to reproduce the following problem (both in simulator and in a Descent MK1 using SDK 3.2.5 and 4.0.6):
If the function setValue is called from onUpdate while makeWebRequest is still waiting for the webserver to return data,
the callback function is "lost" (and not called).
The following code reproduce the problem 100% of the time.
using Toybox.Application;
using Toybox.Background;
using Toybox.System;
using Toybox.WatchUi;
using Toybox.Time;
using Toybox.Communications;
using Toybox.Application.Storage;
(:background)
class PiServiceDelegate extends Toybox.System.ServiceDelegate {
  function initialize() {
    System.ServiceDelegate.initialize();
  function onTemporalEvent() {
    // That URI takes about 3 seconds to answer
    var uri = "https://wb.elaine.fi/pi_slow";
    System.println("Before query");
    var options = {
      :methods => Communications.HTTP_REQUEST_METHOD_GET,
      :responseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_JSON
    Communications.makeWebRequest(uri, null, options,
                                  method(:pi_received));
  function pi_received(code, data) {
    System.println(code);
    System.println(data);
    if (code == 200) {
      Background.exit(data);
(:background)
class PiWatch extends Application.AppBase {
  public function initialize() {
    AppBase.initialize();
  function onBackgroundData(data) {
    System.println("onBackgroundData: " + data);
  function getServiceDelegate() {
    return [new PiServiceDelegate()];
  function getInitialView() {
    Background.registerForTemporalEvent(new Time.Duration(5 * 60));
    return [new PiWatchView(), new PiWatchDelegate()];
class PiWatchView extends WatchUi.WatchFace {
    WatchFace.initialize();
  public function onUpdate(dc) {
    System.println("onUpdate");
    // On simulator, onUpdate is ran every seconds
    // So we will call Storage.setValue between the http request
    // and the result
    // On watch same problem exists
    Storage.setValue("foo", "bar");
    // Note that problem does not exists if Storage.setValue
    // is called in onPartialUpdate
class PiWatchDelegate extends WatchUi.WatchFaceDelegate {
    WatchFaceDelegate.initialize();
Here is the output:
onUpdate
onUpdate
onUpdate
Background: Before query
onUpdate
onUpdate
onUpdate
Error: Symbol Not Found Error
Details: Failed invoking <symbol>
Stack:
onUpdate
onUpdate
onUpdate
If I comment the setValue line, I get the expected result:
onUpdate
onUpdate
onUpdate
onUpdate
onUpdate
onUpdate
onUpdate
Background: 200
Background: {pi=>3.140000}
onBackgroundData: {pi=>3.140000}
onUpdate
onUpdate
onUpdate
Parents
  • What is in your ciq_log file? (Assuming this is on a real device) One thing about the callback you posted for the makeWebRequest, is that it only does an exit if the responseCode==200, which means the backround will run 30 seconds and be killed if you get an error in the call, You'll never see anything in onBackroundData..
    On a real device, the background may not run every 5 minutes, even if that's set for temporal events.  For example, a WF's background won't run the whole time you're using a CIQ device app.
    I've added a setValue() call in onUpdate() in one of my wf's that does comm, and running it the sim as well as on a device, and so far, no issues.
Comment
Children
No Data
