Acknowledged
over 1 year ago
Compiler Bug: Typechecker does not accept ScanResult object for Applicaton.Storage
If i code
Storage.setValue("MyBLE_ScanResult", scanResult as ScanResult);
the type checker complains that ScanResult is not an Application.PropertyValueType.
That's true, but the API says that from v3.2.0 on it is possible to save a ScanResult with Application.Storage.
  • > This seems to be fixed with SDK v7.3.0
    It hasn't been fixed afaict
    I tried to build the following code with the default type checking level, for fr955 with SDK 7.3.0:
       // this function is in the main app class which extends AppBase
        function foo() {
            var scanResult = null;
            Properties.setValue("MyBLE_ScanResult", scanResult as Toybox.BluetoothLowEnergy.ScanResult);  // line 45
            Storage.setValue("MyBLE_ScanResult", scanResult as Toybox.BluetoothLowEnergy.ScanResult);  // line 46
    Result:
    ERROR: fr955: PATH/TO/SOURCE/MC:45,8: Invalid '$.Toybox.BluetoothLowEnergy.ScanResult' passed as parameter 2 of type 'PolyType<Null or $.Toybox.Application.PropertyKeyType or $.Toybox.Lang.Array<$.Toybox.Application.PropertyValueType> or $.Toybox.Lang.Dictionary<$.Toybox.Application.PropertyKeyType,$.Toybox.Application.PropertyValueType> or $.Toybox.WatchUi.BitmapResource>'.
    ERROR: fr955: PATH/TO/SOURCE/MC:46,8: Invalid '$.Toybox.BluetoothLowEnergy.ScanResult' passed as parameter 2 of type 'PolyType<Null or $.Toybox.Application.PropertyKeyType or $.Toybox.Lang.Array<$.Toybox.Application.PropertyValueType> or $.Toybox.Lang.Dictionary<$.Toybox.Application.PropertyKeyType,$.Toybox.Application.PropertyValueType> or $.Toybox.WatchUi.BitmapResource>'.
  • This seems to be fixed with SDK v7.3.0
  • https://developer.garmin.com/connect-iq/core-topics/complications/
    The sample code actually only shows retrieving a complication ID from storage, but my point stands.
  • I *think* the same issue exists for Complications.Id. The complications docs (in the general CIQ dev site, not the API docs) mentioned that a complication ID can be persisted to storage (and provided example code to do so). This originally did not work, but I think it might have been fixed at some point (other than the type checking aspect.)
