Acknowledged
COMPILER BUG: cannot compile classes with static functions
There are several issues with the available compilers (SDK 4.1.7 and SDK 4.2.0 Beta 1) if a class contains a static function and the parameters of the function are Monkey Typed with the compiler set to "Gradual" or higher.
  1. Cannot find symbol errors for functions on core classes (eg. Position.Location); and
  2. Error parsing the global namespace ($.) when specifying the Monkey Type for a function parameter.
I tried the broken, replicateable code on SDK 4.1.5, SDK 4.1.6, SDK 4.1.7 and SDK 4.2.0 Beta 1.
Error #1 occurs only on SDK 4.1.7 (ie. it works fine on SDK 4.1.5, SDK 4.1.6, SDK 4.2.0 Beta 1).
Error #2 occurs on all the SDKs listed above -- SDK 4.1.5, SDK 4.1.6, SDK 4.1.7 and SDK 4.2.0 Beta 1.
These errors may or may not be related to this issue: https://forums.garmin.com/developer/connect-iq/i/bug-reports/bug-report-static-lang-dictionary-class-variable-broken-in-sdk-4-1-6
I am not able to attach my test project that will easily replicate both issues/bugs but I have emailed the ZIP to the Connect IQ team. If anyone would like the project file to validate the issue or use it as the basis for a similar sounding bug or just out of curiosity, then DM me. For reference, the function within the class looks like this:
    static function compilerErrorOne(location as Position.Location, waypoint) as BrokenClass {
        var decimalDeg = location.toDegrees();
        var wpDecDeg = waypoint.getLocation().toDegrees();
        var brokenClass = new BrokenClass(null);
        return (brokenClass);
    static function compilerErrorTwo(location, waypoint as $.Waypoint) as BrokenClass {
Parents
  • I'll add some other example:
    import Toybox.Background;
    import Toybox.Time;
    class Static {
        function nonStaticTest() as Void {
            var lastTime = Background.getTemporalEventRegisteredTime();
            var nextTime = lastTime != null ? lastTime.add(new Time.Duration(300)) : Time.now();
            Background.registerForTemporalEvent(nextTime);
        static function staticTest() as Void {
    staticTest doesn't compile with SDK 4.1.7:
    ERROR: fr255: Test.mc:13,8: Cannot find symbol ':add' on type 'PolyType<$.Toybox.Time.Duration or $.Toybox.Time.Moment>'.
    ERROR: fr255: Test.mc:13,8: Cannot determine type for method invocation.
    ERROR: fr255: Test.mc:14,8: Passing 'Any' as parameter 1 of poly type 'PolyType<$.Toybox.Time.Duration or $.Toybox.Time.Moment>
Comment
    import Toybox.Time;
    class Static {
Children
No Data
