Acknowledged
CIQ Simulator shows "A debugging check in this application has failed" after upgrade Connect IQ SDK 4.2.4
After upgrade Connect IQ SDK, following error shows when I running CIQ emulator with fenix 7X
But other device is fine. Does any anyone have clues to solve this problem?
Connect IQ Device Simulator 4.2.4
2023/6/28: Update to SDK 6.2.0 is same.
  • I have tried to delete affected products from SDK Manager and re-install twice. It's still not work.
  • I have deleted and installed for 2 times, no effect. to  avoid the network issue. maybe you can zip one and I decompression them to the right dir ? my error devices is epix pro series, and  I know the  dir
  • After some discussion with the engineering team, we were wondering if perhaps some of the device config files for the affected devices had not been downloaded. Could each of you try removing the affected products from SDK Manager and then re-install those products to see if that addresses the issue?
  • me too ,just for epix pro 42/47/51
  • Hi Brandon
    Thanks for you reply.
    I have tried to upgrade SDK, re-download Device.
    Only run some devices at Simulator (such as epix2pro42mm, fenix7xpro, fenix7x) will occur these problems, and (descentmk2, fr955, venusq2, vivoactive4, instinctcrossover) seems ok.
    Build and export apps works will.
    Detail of message as following:
    ..\..\src\common\menucmn.cpp(308): assert "wxIsStockID(GetId())" failed in wxMenuItemBase::SetItemLabel(): A non-stock menu item with an empty label?
    ..\..\src\common\stockitem.cpp(219): assert ""Assert failure"" failed in wxGetStockLabel(): invalid stock item ID
