Acknowledged
CIQ Simulator shows "A debugging check in this application has failed" after upgrade Connect IQ SDK 4.2.4
After upgrade Connect IQ SDK, following error shows when I running CIQ emulator with fenix 7X
But other device is fine. Does any anyone have clues to solve this problem?
Connect IQ Device Simulator 4.2.4
2023/6/28: Update to SDK 6.2.0 is same.
Parents
  • Hi Brandon
    Thanks for you reply.
    I have tried to upgrade SDK, re-download Device.
    Only run some devices at Simulator (such as epix2pro42mm, fenix7xpro, fenix7x) will occur these problems, and (descentmk2, fr955, venusq2, vivoactive4, instinctcrossover) seems ok.
    Build and export apps works will.
    Detail of message as following:
    ..\..\src\common\menucmn.cpp(308): assert "wxIsStockID(GetId())" failed in wxMenuItemBase::SetItemLabel(): A non-stock menu item with an empty label?
    ..\..\src\common\stockitem.cpp(219): assert ""Assert failure"" failed in wxGetStockLabel(): invalid stock item ID
Comment
  • Hi Brandon
Children
No Data
