Acknowledged
CIQ Simulator Edit Application.Properties data doesn't show any properties
Hi,
I'm using CIQ Simulator on Linux (UBUNTU 22.04 LTS) with VSCode 1.91.1. I have installed the newest VSCode Extension (v1.0.11) and I'm using the newest SDK (7.2.1)
While running my application from VSCode, when the simulator starts and I try to edit application properties, I get empty window, where I can only change App and Language, but the part below is empty. Hovewer, when I run the simulator directly from my console (ConnectIQ/Sdks/connectiq-sdk-lin-<version>/bin/simulator) I can freely change any properties and everything is working fine.
Saving those empty window results in "Error running JavaScript: Usupported result type"
What I've tried already:
  • re-installing SDK
  • re-installing VSCode extension
  • Simulator -> File -> Delete All Apps
  • removing old .SET files from /tmp/com.garmin.connectiq/GARMIN/APPS/SETTINGS
  • creating new project using template with settings
None of those attempts worked for me.
When I run CIQ simulator directly, I can then build my app to load onto this simulator instance, and change settings, but the app don't update when I save them, only, when I change something like time format or language.
Is that a bug in the software, or is there anything else I can do to reset it to expected behavior?
Parents Comment Children
