Acknowledged
CIQ Simulator crashes when bitmap packingFormat="yuv" on some devices
This has been happening with all SDK versions, including the latest 8.3.0.
For example, instinct3amoled50mm has the following section in compiler.json:
"imageFormats": [
"yuv",
"jpg",
"png"
When I define a bitmap resource with packingFormat="png" or packingFormat="jpg", an app using this bitmap works (although the color reproduction is wrong).
But when I change the definition to packingFormat="yuv", it the simulator crashes on application startup, both on Mac and Windows.
This also happens on other devices (e.g. Instinct AMOLED 45mm, Forerunner 165 Music).
Below is a crash report from Mac:
Translated Report (Full Report Below)
Process: simulator [51023]
Path: /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
Identifier: com.garmin.connectiq.simulator
Version: 8.3.0 (8.3.0)
Code Type: ARM-64 (Native)
Role: Foreground
Parent Process: launchd [1]
Coalition: com.garmin.connectiq.simulator [872]
User ID: 501
Date/Time: 2025-11-27 08:38:32.7346 +0700
Launch Time: 2025-11-25 12:05:13.9057 +0700
Hardware Model: MacBookAir10,1
OS Version: macOS 26.1 (25B78)
Release Type: User
Crash Reporter Key: 277CCC3B-2E88-EAA7-7D3F-B4E208A73F60
Incident Identifier: A8A88BAC-F3FA-4CC3-A9C2-898848DCDDF0
Sleep/Wake UUID: 5D55BE76-2FC3-4B7A-AEE1-3C1595E50661
Time Awake Since Boot: 280000 seconds
Time Since Wake: 1914 seconds
System Integrity Protection: enabled
Triggered by Thread: 32
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Subtype: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 11, Segmentation fault: 11
Terminating Process: exc handler [51023]
VM Region Info: 0 is not in any region. Bytes before following region: 4376674304
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 104dec000-105eb4000 [ 16.8M] r-x/r-x SM=COW /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x19b472c34 mach_msg2_trap + 8
1 libsystem_kernel.dylib 0x19b485028 mach_msg2_internal + 76
2 libsystem_kernel.dylib 0x19b47b98c mach_msg_overwrite + 484
3 libsystem_kernel.dylib 0x19b472fb4 mach_msg + 24
4 CoreFoundation 0x19b554b90 __CFRunLoopServiceMachPort + 160
5 CoreFoundation 0x19b5534e8 __CFRunLoopRun + 1188
6 CoreFoundation 0x19b60d35c _CFRunLoopRunSpecificWithOptions + 532
7 HIToolbox 0x1a8010768 RunCurrentEventLoopInMode + 316
8 HIToolbox 0x1a8013a90 ReceiveNextEventCommon + 488
9 HIToolbox 0x1a819d308 _BlockUntilNextEventMatchingListInMode + 48
10 AppKit 0x19fe643c0 _DPSBlockUntilNextEventMatchingListInMode + 236
11 AppKit 0x19f95de34 _DPSNextEvent + 588
12 AppKit 0x1a042bf44 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 688
13 AppKit 0x1a042bc50 -[NSApplication(NSEventRouting) nextEventMatchingMask:untilDate:inMode:dequeue:] + 72
14 AppKit 0x19f956780 -[NSApplication run] + 368
15 simulator 0x1058d612c 0x104dec000 + 11444524
16 simulator 0x1057eadb8 0x104dec000 + 10481080
17 simulator 0x10576abc8 0x104dec000 + 9956296
18 simulator 0x10573df64 0x104dec000 + 9772900
19 simulator 0x105897774 0x104dec000 + 11188084
20 simulator 0x105798a7c 0x104dec000 + 10144380
21 simulator 0x104e24e3c 0x104dec000 + 233020
22 dyld 0x19b0edd54 start + 7184
Thread 1:: com.apple.NSEventThread
7 AppKit 0x19f9edcb4 _NSEventThread + 184
8 libsystem_pthread.dylib 0x19b4b5c08 _pthread_start + 136
9 libsystem_pthread.dylib 0x19b4b0ba8 thread_start + 8
Thread 2:: TSK bkgd
0 libsystem_kernel.dylib 0x19b4764f8 __psynch_cvwait + 8
1 libsystem_pthread.dylib 0x19b4b60dc _pthread_cond_wait + 984
2 simulator 0x10560cef0 0x104dec000 + 8523504
3 simulator 0x10560c164 0x104dec000 + 8520036
4 libsystem_pthread.dylib 0x19b4b5c08 _pthread_start + 136
5 libsystem_pthread.dylib 0x19b4b0ba8 thread_start + 8
Thread 3:: NFM_Region_0
3 simulator 0x1056886ac 0x104dec000 + 9029292
4 simulator 0x10560c198 0x104dec000 + 8520088
5 libsystem_pthread.dylib 0x19b4b5c08 _pthread_start + 136
6 libsystem_pthread.dylib 0x19b4b0ba8 thread_start + 8
Thread 4:: Cache Mngr
2 simulator 0x10560ba0c 0x104dec000 + 8518156
3 simulator 0x105613e0c 0x104dec000 + 8551948
4 simulator 0x1056410c4 0x104dec000 + 8736964
5 simulator 0x10563dac8 0x104dec000 + 8723144
6 simulator 0x10560c198 0x104dec000 + 8520088
7 libsystem_pthread.dylib 0x19b4b5c08 _pthread_start + 136
8 libsystem_pthread.dylib 0x19b4b0ba8 thread_start + 8
Thread 5:: IOPAppMain
3 simulator 0x105362044 0x104dec000 + 5726276
4 simulator 0x10560c180 0x104dec000 + 8520064
Thread 6:: ant_main
2 libc++.1.dylib 0x19b3e67e4 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>>>) + 104
3 simulator 0x1057227f0 0x104dec000 + 9660400
4 simulator 0x1057207d8 0x104dec000 + 9652184
5 simulator 0x10572a13c 0x104dec000 + 9691452
6 simulator 0x10570c810 0x104dec000 + 9570320
7 simulator 0x10570f87c 0x104dec000 + 9582716
8 simulator 0x1053727c4 0x104dec000 + 5793732
9 simulator 0x104f4717c 0x104dec000 + 1421692
10 simulator 0x105614f70 0x104dec000 + 8556400
11 simulator 0x10531c454 0x104dec000 + 5440596
12 simulator 0x105333808 0x104dec000 + 5535752
13 simulator 0x10560c180 0x104dec000 + 8520064
14 libsystem_pthread.dylib 0x19b4b5c08 _pthread_start + 136
15 libsystem_pthread.dylib 0x19b4b0ba8 thread_start + 8
Thread 7:: GPS main
Thread 8:: SNS main
Thread 9:: fit activity
3 simulator 0x1053a046c 0x104dec000 + 5981292
Thread 10:: ftm main
1 libsystem_pthread.dylib 0x19b4b6108 _pthread_cond_wait + 1028
2 simulator 0x10560bc5c 0x104dec000 + 8518748
3 simulator 0x10560cef0 0x104dec000 + 8523504
4 simulator 0x1053af554 0x104dec000 + 6042964
5 simulator 0x10560c180 0x104dec000 + 8520064
6 libsystem_pthread.dylib 0x19b4b5c08 _pthread_start + 136
7 libsystem_pthread.dylib 0x19b4b0ba8 thread_start + 8
Thread 11:: TVM main
4 simulator 0x1055ae554 0x104dec000 + 8136020
Thread 12:: parse main
4 simulator 0x104e0bf08 0x104dec000 + 130824
Thread 13:: GPX archive trk
3 simulator 0x10569b89c 0x104dec000 + 9107612
Thread 14:: URM Main
3 simulator 0x105384e50 0x104dec000 + 5869136
Thread 15:: mma sql bkg
Thread 16:: TLG main
4 simulator 0x10569b660 0x104dec000 + 9107040
5 simulator 0x10560c198 0x104dec000 + 8520088
Thread 17:: libcurl Async H
3 simulator 0x10537d44c 0x104dec000 + 5837900
Thread 18:: Download Manage
3 simulator 0x10537ffc8 0x104dec000 + 5849032
Thread 19:: Shell main
0 libsystem_kernel.dylib 0x19b47b694 __accept + 8
1 simulator 0x1056940b0 0x104dec000 + 9076912
2 simulator 0x1056912d4 0x104dec000 + 9065172
Thread 20:
2 libc++.1.dylib 0x19b3e674c std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 32
3 simulator 0x104eba794 0x104dec000 + 845716
4 simulator 0x104eba658 0x104dec000 + 845400
5 simulator 0x104eba504 0x104dec000 + 845060
Thread 21:
1 simulator 0x104f2ba9c 0x104dec000 + 1309340
2 simulator 0x104ef0d84 0x104dec000 + 1068420
3 simulator 0x1057faf74 0x104dec000 + 10547060
Thread 22:: WebCore: Scrolling
7 CoreFoundation 0x19b5a6a30 CFRunLoopRun + 64
8 JavaScriptCore 0x1bca74198 WTF::Detail::CallableWrapper<WTF::RunLoop::create(WTF::ASCIILiteral, WTF::ThreadType, WTF::Thread::QOS)::$_0, void>::call() + 244
9 JavaScriptCore 0x1bcab6e5c WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*) + 260
10 JavaScriptCore 0x1bc881490 WTF::wtfThreadEntryPoint(void*) + 16
11 libsystem_pthread.dylib 0x19b4b5c08 _pthread_start + 136
12 libsystem_pthread.dylib 0x19b4b0ba8 thread_start + 8
Thread 23:: Log work queue
0 libsystem_kernel.dylib 0x19b472bb0 semaphore_wait_trap + 8
1 WebKit 0x1c5a8a6b4 IPC::StreamConnectionWorkQueue::startProcessingThread()::$_0::operator()() + 44
2 JavaScriptCore 0x1bcab6e5c WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*) + 260
3 JavaScriptCore 0x1bc881490 WTF::wtfThreadEntryPoint(void*) + 16
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:: JavaScriptCore libpas scavenger
2 JavaScriptCore 0x1be177f54 scavenger_thread_main + 1660
3 libsystem_pthread.dylib 0x19b4b5c08 _pthread_start + 136
4 libsystem_pthread.dylib 0x19b4b0ba8 thread_start + 8
Thread 30:: Shell handler
3 simulator 0x104f2af48 0x104dec000 + 1306440
4 simulator 0x105693de8 0x104dec000 + 9076200
5 simulator 0x105693468 0x104dec000 + 9073768
6 simulator 0x105691cd0 0x104dec000 + 9067728
7 simulator 0x10560c180 0x104dec000 + 8520064
Thread 31:
0 libsystem_kernel.dylib 0x19b4773a4 __recvfrom + 8
1 simulator 0x10569449c 0x104dec000 + 9077916
2 simulator 0x105693528 0x104dec000 + 9073960
3 simulator 0x104f27c04 0x104dec000 + 1293316
4 simulator 0x104f2fbd0 0x104dec000 + 1326032
5 simulator 0x1057faf74 0x104dec000 + 10547060
Thread 32 Crashed:
0 simulator 0x10543ba30 0x104dec000 + 6617648
1 simulator 0x10543b7a8 0x104dec000 + 6617000
2 simulator 0x105431800 0x104dec000 + 6576128
3 simulator 0x105508f5c 0x104dec000 + 7458652
4 simulator 0x10559d860 0x104dec000 + 8067168
5 simulator 0x105594f2c 0x104dec000 + 8032044
6 simulator 0x105594e64 0x104dec000 + 8031844
7 simulator 0x1055f7c00 0x104dec000 + 8436736
8 simulator 0x1055fc228 0x104dec000 + 8454696
9 simulator 0x1055fcc7c 0x104dec000 + 8457340
10 simulator 0x1055fd674 0x104dec000 + 8459892
11 simulator 0x10559bf1c 0x104dec000 + 8060700
12 simulator 0x1055ec7a4 0x104dec000 + 8390564
13 simulator 0x104f9d260 0x104dec000 + 1774176
14 simulator 0x104f9ce0c 0x104dec000 + 1773068
15 simulator 0x104f4aeec 0x104dec000 + 1437420
16 simulator 0x104f4838c 0x104dec000 + 1426316
17 simulator 0x104f2fbd0 0x104dec000 + 1326032
18 simulator 0x1057faf74 0x104dec000 + 10547060
19 libsystem_pthread.dylib 0x19b4b5c08 _pthread_start + 136
20 libsystem_pthread.dylib 0x19b4b0ba8 thread_start + 8
Thread 32 crashed with ARM Thread State (64-bit):
x0: 0x00000008189b404c x1: 0x00000008189b4358 x2: 0x0000000000000000 x3: 0x0000000000000000
x4: 0x0000000000000000 x5: 0x0000000000000000 x6: 0x0000000000000000 x7: 0x0000000000000186
x8: 0x0000000000000000 x9: 0x00000008189b4358 x10: 0x000000000000030c x11: 0x000000000000ffff
x12: 0x00000008189b404c x13: 0x0000000000000000 x14: 0x000000010543b920 x15: 0x00000008189b404c
x16: 0x0000000000000000 x17: 0x0000000000000000 x18: 0x0000000000000000 x19: 0x000000000000030c
x20: 0x00000008189b404c x21: 0x000000000000030c x22: 0x0000000000000000 x23: 0x0000000000000000
x24: 0x000000010543b920 x25: 0x0000000000000000 x26: 0x0000000000000000 x27: 0x0000000000000000
x28: 0x0000000000000186 fp: 0x000000016b23e520 lr: 0x000000010543b7a8
sp: 0x000000016b23e4b0 pc: 0x000000010543ba30 cpsr: 0x00001000
far: 0x0000000000000000 esr: 0x92000046 (Data Abort) byte write Translation fault
Binary Images:
0x104dec000 - 0x105eb3fff com.garmin.connectiq.simulator (8.3.0) <dcfc72f9-28ac-3626-8257-1cdc8d881c27> /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
0x1064bc000 - 0x1064c7fff libobjc-trampolines.dylib (*) <f8bd9069-8c4f-37ea-af9a-2b1060f54e4f> /usr/lib/libobjc-trampolines.dylib
0x11e03c000 - 0x11e787fff com.apple.AGXMetal13-3 (341.11) <bfb2418e-640c-30a5-afde-569c93fb8ae5> /System/Library/Extensions/AGXMetal13_3.bundle/Contents/MacOS/AGXMetal13_3
0x11f658000 - 0x11f6bbfff com.apple.AppleMetalOpenGLRenderer (1.0) <7fba6cd5-06ae-37aa-aa67-580c920ea69d> /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer
0x19b472000 - 0x19b4ae49f libsystem_kernel.dylib (*) <9fe7c84d-0c2b-363f-bee5-6fd76d67a227> /usr/lib/system/libsystem_kernel.dylib
0x19b4f5000 - 0x19ba3babf com.apple.CoreFoundation (6.9) <3c4a3add-9e48-33da-82ee-80520e6cbe3b> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x1a7f4f000 - 0x1a82517ff com.apple.HIToolbox (2.1.1) <9ab64c08-0685-3a0d-9a7e-83e7a1e9ebb4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x19f93e000 - 0x1a106ab9f com.apple.AppKit (6.9) <3c0949bb-e361-369a-80b7-17440eb09e98> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x19b0e5000 - 0x19b183f63 dyld (*) <b50f5a1a-be81-3068-92e1-3554f2be478a> /usr/lib/dyld
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x19b4af000 - 0x19b4bbabb libsystem_pthread.dylib (*) <e95973b8-824c-361e-adf4-390747c40897> /usr/lib/system/libsystem_pthread.dylib
0x19b3c4000 - 0x19b456e53 libc++.1.dylib (*) <b29f2164-26b0-3016-a871-82de5a4637ff> /usr/lib/libc++.1.dylib
0x1bc87a000 - 0x1be398e7f com.apple.JavaScriptCore (21622) <c79071c9-db50-3264-a316-94abd0d3b9a9> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x1c4968000 - 0x1c5e828bf com.apple.WebKit (21622) <3b55482a-efe2-35a7-b1c9-3f41a823a30b> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.8G resident=0K(0%) swapped_out_or_unallocated=1.8G(100%)
Writable regions: Total=4.7G written=1828K(0%) resident=948K(0%) swapped_out=880K(0%) unallocated=4.7G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 2
Activity Tracing 256K 1
AttributeGraph Data 1024K 1
CG image 3248K 14
CG raster data 2352K 6
ColorSync 48K 3
CoreAnimation 1984K 72
CoreGraphics 32K 2
CoreUI image data 4112K 32
Dispatch continuations 64.0M 1
Foundation 48K 2
Image IO 128K 2
Kernel Alloc Once 32K 1
MALLOC 266.9M 65
MALLOC guard page 3840K 4
STACK GUARD 56.5M 33
Stack 26.7M 87
VM_ALLOCATE 87.6M 279
VM_ALLOCATE (reserved) 4.0G 1 reserved VM address space (unallocated)
WebKit Malloc 192.1M 7
WebKit Malloc (reserved) 64.0M 1 reserved VM address space (unallocated)
__AUTH 5849K 655
__AUTH_CONST 88.8M 1039
__CTF 824 1
__DATA 31.5M 988
__DATA_CONST 33.8M 1047
__DATA_DIRTY 8837K 899
__FONT_DATA 2352 1
__GLSLBUILTINS 5174K 1
__INFO_FILTER 8 1
__LINKEDIT 595.4M 5
__OBJC_RO 78.3M 1
__OBJC_RW 2567K 1
__TEXT 1.2G 1070
__TPRO_CONST 128K 2
mapped file 636.0M 66
page table in kernel 948K 1
shared memory 928K 16
TOTAL 7.4G 6410
TOTAL, minus reserved VM space 3.4G 6410
Full Report
{"app_name":"simulator","timestamp":"2025-11-27 08:39:09.00 +0700","app_version":"8.3.0","slice_uuid":"dcfc72f9-28ac-3626-8257-1cdc8d881c27","build_version":"8.3.0","platform":1,"bundleID":"com.garmin.connectiq.simulator","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 26.1 (25B78)","roots_installed":0,"name":"simulator","incident_id":"A8A88BAC-F3FA-4CC3-A9C2-898848DCDDF0"}
"uptime" : 280000,
"procRole" : "Foreground",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "MacBookAir10,1",
"coalitionID" : 872,
"osVersion" : {
"train" : "macOS 26.1",
"build" : "25B78",
"releaseType" : "User"
"captureTime" : "2025-11-27 08:38:32.7346 +0700",
"codeSigningMonitor" : 1,
"incident" : "A8A88BAC-F3FA-4CC3-A9C2-898848DCDDF0",
"pid" : 51023,
"translated" : false,
"cpuType" : "ARM-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2025-11-25 12:05:13.9057 +0700",
"procStartAbsTime" : 5486335825300,
"procExitAbsTime" : 6764127896711,
"procName" : "simulator",
"procPath" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
"bundleInfo" : {"CFBundleShortVersionString":"8.3.0","CFBundleVersion":"8.3.0","CFBundleIdentifier":"com.garmin.connectiq.simulator"},
"storeInfo" : {"deviceIdentifierForVendor":"8328F350-2F45-5923-BD5F-2C5ABB306647","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.garmin.connectiq.simulator",
"crashReporterKey" : "277CCC3B-2E88-EAA7-7D3F-B4E208A73F60",
"appleIntelligenceStatus" : {"state":"available"},
"developerMode" : 1,
"bootProgressRegister" : "0x3f000000",
"codeSigningID" : "com.garmin.connectiq.simulator",
"codeSigningTeamID" : "72ES32VZUA",
"codeSigningFlags" : 570503953,
"codeSigningValidationCategory" : 6,
"codeSigningTrustLevel" : 4294967295,
"codeSigningAuxiliaryInfo" : 0,
"instructionByteStream" : {"beforePC":"rX0QU78BC2uBAwBUjQ1AuX8BLWqhAwBUrX0QU78BC2tg\/P9UHQAAFA==","atPC":"DQEAea19EFO\/AQtrQP3\/VA0FAHmNBUC5fwEtaiD9\/1QNCQB5rX0QUw=="},
"bootSessionUUID" : "249A3C81-3FF1-46F4-8446-C20F6E1CE596",
"wakeTime" : 1914,
"sleepWakeUUID" : "5D55BE76-2FC3-4B7A-AEE1-3C1595E50661",
"sip" : "enabled",
"vmRegionInfo" : "0 is not in any region. Bytes before following region: 4376674304\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 104dec000-105eb4000 [ 16.8M] r-x\/r-x SM=COW \/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
"exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000000"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":51023},
"vmregioninfo" : "0 is not in any region. Bytes before following region: 4376674304\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 104dec000-105eb4000 [ 16.8M] r-x\/r-x SM=COW \/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 32,
"threads" : [{"id":3440581,"threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":27500675596288},{"value":0},{"value":27500675596288},{"value":2},{"value":4294967295},{"value":0},{"value":17179869184},{"value":0},{"value":2},{"value":0},{"value":0},{"value":6403},{"value":0},{"value":18446744073709551569},{"value":8745638640},{"value":0},{"value":4294967295},{"value":2},{"value":27500675596288},{"value":0},{"value":27500675596288},{"value":6090200504},{"value":8589934592},{"value":21592279046},{"value":18446744073709550527},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900174888},"cpsr":{"value":4096},"fp":{"value":6090200352},"sp":{"value":6090200272},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900100148},"far":{"value":0}},"queue":"com.apple.main-thread","frames":[{"imageOffset":3124,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":4},{"imageOffset":77864,"symbol":"mach_msg2_internal","symbolLocation":76,"imageIndex":4},{"imageOffset":39308,"symbol":"mach_msg_overwrite","symbolLocation":484,"imageIndex":4},{"imageOffset":4020,"symbol":"mach_msg","symbolLocation":24,"imageIndex":4},{"imageOffset":392080,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":5},{"imageOffset":386280,"symbol":"__CFRunLoopRun","symbolLocation":1188,"imageIndex":5},{"imageOffset":1147740,"symbol":"_CFRunLoopRunSpecificWithOptions","symbolLocation":532,"imageIndex":5},{"imageOffset":792424,"symbol":"RunCurrentEventLoopInMode","symbolLocation":316,"imageIndex":6},{"imageOffset":805520,"symbol":"ReceiveNextEventCommon","symbolLocation":488,"imageIndex":6},{"imageOffset":2417416,"symbol":"_BlockUntilNextEventMatchingListInMode","symbolLocation":48,"imageIndex":6},{"imageOffset":5399488,"symbol":"_DPSBlockUntilNextEventMatchingListInMode","symbolLocation":236,"imageIndex":7},{"imageOffset":130612,"symbol":"_DPSNextEvent","symbolLocation":588,"imageIndex":7},{"imageOffset":11460420,"symbol":"-[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":688,"imageIndex":7},{"imageOffset":11459664,"symbol":"-[NSApplication(NSEventRouting) nextEventMatchingMask:untilDate:inMode:dequeue:]","symbolLocation":72,"imageIndex":7},{"imageOffset":100224,"symbol":"-[NSApplication run]","symbolLocation":368,"imageIndex":7},{"imageOffset":11444524,"imageIndex":0},{"imageOffset":10481080,"imageIndex":0},{"imageOffset":9956296,"imageIndex":0},{"imageOffset":9772900,"imageIndex":0},{"imageOffset":11188084,"imageIndex":0},{"imageOffset":10144380,"imageIndex":0},{"imageOffset":233020,"imageIndex":0},{"imageOffset":36180,"symbol":"start","symbolLocation":7184,"imageIndex":8}]},{"id":3440613,"name":"com.apple.NSEventThread","threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":127556233723904},{"value":0},{"value":127556233723904},{"value":2},{"value":4294967295},{"value":0},{"value":17179869184},{"value":0},{"value":2},{"value":0},{"value":0},{"value":29699},{"value":0},{"value":18446744073709551569},{"value":8745638640},{"value":0},{"value":4294967295},{"value":2},{"value":127556233723904},{"value":0},{"value":127556233723904},{"value":6094200968},{"value":8589934592},{"value":21592279046},{"value":18446744073709550527},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900174888},"cpsr":{"value":4096},"fp":{"value":6094200816},"sp":{"value":6094200736},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900100148},"far":{"value":0}},"frames":[{"imageOffset":3124,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":4},{"imageOffset":77864,"symbol":"mach_msg2_internal","symbolLocation":76,"imageIndex":4},{"imageOffset":39308,"symbol":"mach_msg_overwrite","symbolLocation":484,"imageIndex":4},{"imageOffset":4020,"symbol":"mach_msg","symbolLocation":24,"imageIndex":4},{"imageOffset":392080,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":5},{"imageOffset":386280,"symbol":"__CFRunLoopRun","symbolLocation":1188,"imageIndex":5},{"imageOffset":1147740,"symbol":"_CFRunLoopRunSpecificWithOptions","symbolLocation":532,"imageIndex":5},{"imageOffset":720052,"symbol":"_NSEventThread","symbolLocation":184,"imageIndex":7},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440641,"name":"TSK bkgd","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6094777960},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34733883544},{"value":34733883608},{"value":6094778592},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6094778080},"sp":{"value":6094777936},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":8520036,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440642,"name":"NFM_Region_0","threadState":{"x":[{"value":260},{"value":0},{"value":88320},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6095351144},{"value":0},{"value":11776},{"value":50577534889474},{"value":50577534889474},{"value":11776},{"value":0},{"value":50577534889472},{"value":305},{"value":8745636760},{"value":0},{"value":34733883992},{"value":34733884056},{"value":6095352032},{"value":0},{"value":0},{"value":88320},{"value":88321},{"value":88576},{"value":34748857368},{"value":65535}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6095351264},"sp":{"value":6095351120},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":9029292,"imageIndex":0},{"imageOffset":8520088,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440643,"name":"Cache Mngr","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6095924600},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34747139168},{"value":34747139272},{"value":6095925472},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":4294967295},{"value":6095924992}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6095924720},"sp":{"value":6095924576},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8518156,"imageIndex":0},{"imageOffset":8551948,"imageIndex":0},{"imageOffset":8736964,"imageIndex":0},{"imageOffset":8723144,"imageIndex":0},{"imageOffset":8520088,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440645,"name":"IOPAppMain","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6096498200},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34733884888},{"value":34733884952},{"value":6096498912},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6096498320},"sp":{"value":6096498176},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":5726276,"imageIndex":0},{"imageOffset":8520064,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440646,"name":"ant_main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":160},{"value":2},{"value":999987333},{"value":6097070536},{"value":0},{"value":512},{"value":2199023256066},{"value":2199023256066},{"value":512},{"value":0},{"value":2199023256064},{"value":305},{"value":8745636760},{"value":0},{"value":34732739880},{"value":34732739944},{"value":6097072352},{"value":999987333},{"value":2},{"value":256},{"value":257},{"value":512},{"value":4378095972},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6097070656},"sp":{"value":6097070512},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":141284,"symbol":"std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>>>)","symbolLocation":104,"imageIndex":11},{"imageOffset":9660400,"imageIndex":0},{"imageOffset":9652184,"imageIndex":0},{"imageOffset":9691452,"imageIndex":0},{"imageOffset":9570320,"imageIndex":0},{"imageOffset":9582716,"imageIndex":0},{"imageOffset":5793732,"imageIndex":0},{"imageOffset":1421692,"imageIndex":0},{"imageOffset":8556400,"imageIndex":0},{"imageOffset":5440596,"imageIndex":0},{"imageOffset":5535752,"imageIndex":0},{"imageOffset":8520064,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440647,"name":"GPS main","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6097645160},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34733885784},{"value":34733885848},{"value":6097645792},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6097645280},"sp":{"value":6097645136},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":8520036,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440648,"name":"SNS main","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6098218600},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34733886232},{"value":34733886296},{"value":6098219232},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6098218720},"sp":{"value":6098218576},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":8520036,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440649,"name":"fit activity","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6098790424},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34733886680},{"value":34733886744},{"value":6098792672},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":4396748424},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6098790544},"sp":{"value":6098790400},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":5981292,"imageIndex":0},{"imageOffset":8520064,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440650,"name":"ftm main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":998932000},{"value":13705217},{"value":0},{"value":256},{"value":1099511628034},{"value":1099511628034},{"value":256},{"value":0},{"value":1099511628032},{"value":305},{"value":8745636760},{"value":0},{"value":34733887128},{"value":34733887192},{"value":1},{"value":998932000},{"value":0},{"value":256},{"value":13705217},{"value":13705472},{"value":4395487232,"symbolLocation":33240,"symbol":"guard variable for wxAnyValueTypeImpl<std::__1::function<void ()>>::sm_instance"},{"value":1}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375816},"cpsr":{"value":2684358656},"fp":{"value":6099364272},"sp":{"value":6099364128},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28936,"symbol":"_pthread_cond_wait","symbolLocation":1028,"imageIndex":10},{"imageOffset":8518748,"imageIndex":0},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":6042964,"imageIndex":0},{"imageOffset":8520064,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440651,"name":"TVM main","threadState":{"x":[{"value":260},{"value":0},{"value":27352832},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":997266000},{"value":27352833},{"value":0},{"value":358912},{"value":1541515302500866},{"value":1541515302500866},{"value":358912},{"value":0},{"value":1541515302500864},{"value":305},{"value":8745636760},{"value":0},{"value":34733887576},{"value":34733887640},{"value":1},{"value":997266000},{"value":0},{"value":27352832},{"value":27352833},{"value":27353088},{"value":4396802048},{"value":4396101632}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375816},"cpsr":{"value":2684358656},"fp":{"value":6099938832},"sp":{"value":6099938688},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28936,"symbol":"_pthread_cond_wait","symbolLocation":1028,"imageIndex":10},{"imageOffset":8518748,"imageIndex":0},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":8136020,"imageIndex":0},{"imageOffset":8520064,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440656,"name":"parse main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":998998000},{"value":13706753},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34733888024},{"value":34733888088},{"value":1},{"value":998998000},{"value":0},{"value":256},{"value":13706753},{"value":13707008},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375816},"cpsr":{"value":2684358656},"fp":{"value":6100511264},"sp":{"value":6100511120},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28936,"symbol":"_pthread_cond_wait","symbolLocation":1028,"imageIndex":10},{"imageOffset":8518748,"imageIndex":0},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":130824,"imageIndex":0},{"imageOffset":8520064,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440657,"name":"GPX archive trk","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6101085592},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34733888472},{"value":34733888536},{"value":6101086432},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":5400},{"value":214749}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6101085712},"sp":{"value":6101085568},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":9107612,"imageIndex":0},{"imageOffset":8520064,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440658,"name":"URM Main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6101659208},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34733888920},{"value":34733888984},{"value":6101659872},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6101659328},"sp":{"value":6101659184},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":5869136,"imageIndex":0},{"imageOffset":8520064,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440659,"name":"mma sql bkg","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6102232680},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34733889368},{"value":34733889432},{"value":6102233312},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6102232800},"sp":{"value":6102232656},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":8520036,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440696,"name":"TLG main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":15016},{"value":999816000},{"value":513},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34733889816},{"value":34733889880},{"value":1},{"value":999816000},{"value":15016},{"value":256},{"value":513},{"value":768},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375816},"cpsr":{"value":2684358656},"fp":{"value":6103379568},"sp":{"value":6103379424},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28936,"symbol":"_pthread_cond_wait","symbolLocation":1028,"imageIndex":10},{"imageOffset":8518748,"imageIndex":0},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":9107040,"imageIndex":0},{"imageOffset":8520088,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440697,"name":"libcurl Async H","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6103952872},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34733890264},{"value":34733890328},{"value":6103953632},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":6103953168},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6103952992},"sp":{"value":6103952848},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":5837900,"imageIndex":0},{"imageOffset":8520088,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440698,"name":"Download Manage","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6104526200},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34733890712},{"value":34733890776},{"value":6104527072},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":4391177045,"symbolLocation":406613,"symbol":"std::__1::piecewise_construct"},{"value":4396715592}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6104526320},"sp":{"value":6104526176},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8523504,"imageIndex":0},{"imageOffset":5849032,"imageIndex":0},{"imageOffset":8520088,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440699,"name":"Shell main","threadState":{"x":[{"value":4},{"value":0},{"value":0},{"value":4402233312},{"value":34678293040},{"value":0},{"value":18446744072631617535},{"value":18446726482597246976},{"value":4385752448},{"value":4385752288},{"value":2},{"value":1},{"value":2455580},{"value":531069180163637785},{"value":4590728648},{"value":34678292480},{"value":30},{"value":20135114780},{"value":0},{"value":34678293040},{"value":4395491328,"symbolLocation":848,"symbol":"guard variable for RequestConsolidator::getInstance()::sSelf"},{"value":4396904448},{"value":4396906756},{"value":4396904448},{"value":2048},{"value":4396904448},{"value":4396906752},{"value":16},{"value":4}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4385751216},"cpsr":{"value":1610616832},"fp":{"value":6105100048},"sp":{"value":6105099984},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900135572},"far":{"value":0}},"frames":[{"imageOffset":38548,"symbol":"__accept","symbolLocation":8,"imageIndex":4},{"imageOffset":9076912,"imageIndex":0},{"imageOffset":9065172,"imageIndex":0},{"imageOffset":8520064,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3440706,"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":141132,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":32,"imageIndex":11},{"imageOffset":845716,"imageIndex":0},{"imageOffset":845400,"imageIndex":0},{"imageOffset":845060,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":260},{"value":0},{"value":70400},{"value":0},{"value":0},{"value":160},{"value":0},{"value":0},{"value":6105673272},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8745636760},{"value":0},{"value":34746576352},{"value":34746576416},{"value":6105673952},{"value":0},{"value":0},{"value":70400},{"value":70401},{"value":70656},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6105673392},"sp":{"value":6105673248},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}}},{"id":3440707,"frames":[{"imageOffset":38548,"symbol":"__accept","symbolLocation":8,"imageIndex":4},{"imageOffset":1309340,"imageIndex":0},{"imageOffset":1068420,"imageIndex":0},{"imageOffset":10547060,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":0},{"value":6106819952},{"value":34746031312},{"value":1},{"value":1},{"value":18446726482597246976},{"value":1},{"value":12808126665516908719},{"value":2},{"value":0},{"value":1024},{"value":531069180237405433},{"value":4402449640},{"value":34746023936},{"value":30},{"value":29276242944},{"value":0},{"value":34741663904},{"value":34742239808},{"value":4396105608},{"value":4377742880},{"value":6106820344},{"value":4395496857,"symbolLocation":41,"symbol":"guard variable for wxAnyValueTypeImpl<wxVariant>::sm_instance"},{"value":6106820296},{"value":4396519424},{"value":6106820608},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4377983644},"cpsr":{"value":1610616832},"fp":{"value":6106820000},"sp":{"value":6106819968},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900135572},"far":{"value":0}}},{"id":3449533,"name":"WebCore: Scrolling","threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":327942227886080},{"value":0},{"value":327942227886080},{"value":2},{"value":4294967295},{"value":0},{"value":17179869184},{"value":0},{"value":2},{"value":0},{"value":0},{"value":76355},{"value":0},{"value":18446744073709551569},{"value":8745638640},{"value":0},{"value":4294967295},{"value":2},{"value":327942227886080},{"value":0},{"value":327942227886080},{"value":6111977416},{"value":8589934592},{"value":21592279046},{"value":18446744073709550527},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900174888},"cpsr":{"value":4096},"fp":{"value":6111977264},"sp":{"value":6111977184},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900100148},"far":{"value":0}},"frames":[{"imageOffset":3124,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":4},{"imageOffset":77864,"symbol":"mach_msg2_internal","symbolLocation":76,"imageIndex":4},{"imageOffset":39308,"symbol":"mach_msg_overwrite","symbolLocation":484,"imageIndex":4},{"imageOffset":4020,"symbol":"mach_msg","symbolLocation":24,"imageIndex":4},{"imageOffset":392080,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":5},{"imageOffset":386280,"symbol":"__CFRunLoopRun","symbolLocation":1188,"imageIndex":5},{"imageOffset":1147740,"symbol":"_CFRunLoopRunSpecificWithOptions","symbolLocation":532,"imageIndex":5},{"imageOffset":727600,"symbol":"CFRunLoopRun","symbolLocation":64,"imageIndex":5},{"imageOffset":2072984,"symbol":"WTF::Detail::CallableWrapper<WTF::RunLoop::create(WTF::ASCIILiteral, WTF::ThreadType, WTF::Thread::QOS)::$_0, void>::call()","symbolLocation":244,"imageIndex":12},{"imageOffset":2346588,"symbol":"WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*)","symbolLocation":260,"imageIndex":12},{"imageOffset":29840,"symbol":"WTF::wtfThreadEntryPoint(void*)","symbolLocation":16,"imageIndex":12},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":3449650,"name":"Log work queue","threadState":{"x":[{"value":14},{"value":5268931432},{"value":142},{"value":4},{"value":1},{"value":0},{"value":0},{"value":1027},{"value":0},{"value":86},{"value":87},{"value":58},{"value":16},{"value":0},{"value":0},{"value":2},{"value":18446744073709551580},{"value":8745641112},{"value":0},{"value":5268718848},{"value":5268718888},{"value":6115422208},{"value":0},{"value":0},{"value":5268718976},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":7611131572},"cpsr":{"value":2147487744},"fp":{"value":6115422032},"sp":{"value":6115422016},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900100016},"far":{"value":0}},"frames":[{"imageOffset":2992,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":4},{"imageOffset":17966772,"symbol":"IPC::StreamConnectionWorkQueue::startProcessingThread()::$_0::operator()()","symbolLocation":44,"imageIndex":13},{"imageOffset":2346588,"symbol":"WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*)","symbolLocation":260,"imageIndex":12},{"imageOffset":29840,"symbol":"WTF::wtfThreadEntryPoint(void*)","symbolLocation":16,"imageIndex":12},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":4310749,"frames":[],"threadState":{"x":[{"value":6118289408},{"value":259391},{"value":6117752832},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6118289408},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900353940},"far":{"value":0}}},{"id":4314548,"frames":[],"threadState":{"x":[{"value":6138933248},{"value":167139},{"value":6138396672},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6138933248},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900353940},"far":{"value":0}}},{"id":4315311,"frames":[],"threadState":{"x":[{"value":6091337728},{"value":245823},{"value":6090801152},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6091337728},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900353940},"far":{"value":0}}},{"id":4315365,"frames":[],"threadState":{"x":[{"value":6138359808},{"value":133635},{"value":6137823232},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6138359808},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900353940},"far":{"value":0}}},{"id":4315366,"frames":[],"threadState":{"x":[{"value":6139506688},{"value":0},{"value":6138970112},{"value":0},{"value":278531},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6139506688},"esr":{"value":0},"pc":{"value":6900353940},"far":{"value":0}}},{"id":4319361,"name":"JavaScriptCore libpas scavenger","threadState":{"x":[{"value":260},{"value":0},{"value":5667328},{"value":0},{"value":0},{"value":160},{"value":9},{"value":999999904},{"value":6090763944},{"value":0},{"value":18432},{"value":79164837218306},{"value":79164837218306},{"value":18432},{"value":0},{"value":79164837218304},{"value":305},{"value":8745636760},{"value":0},{"value":5124843584},{"value":5124843648},{"value":6090764512},{"value":999999904},{"value":9},{"value":5667328},{"value":5674753},{"value":5675008},{"value":8695750656,"symbolLocation":2744,"symbol":"WTF::RefLogSingleton::s_buffer"},{"value":8725254144,"symbolLocation":1816,"symbol":"bmalloc_common_primitive_heap_support"}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6090764064},"sp":{"value":6090763920},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":26206036,"symbol":"scavenger_thread_main","symbolLocation":1660,"imageIndex":12},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":4319425,"name":"Shell handler","threadState":{"x":[{"value":260},{"value":0},{"value":13056},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6091910536},{"value":0},{"value":3840},{"value":16492674420482},{"value":16492674420482},{"value":3840},{"value":0},{"value":16492674420480},{"value":305},{"value":8745636760},{"value":0},{"value":4396065832},{"value":4396065928},{"value":6091911392},{"value":0},{"value":0},{"value":13056},{"value":13057},{"value":13312},{"value":4395505288},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6900375772},"cpsr":{"value":1610616832},"fp":{"value":6091910656},"sp":{"value":6091910512},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900114680},"far":{"value":0}},"frames":[{"imageOffset":17656,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":4},{"imageOffset":28892,"symbol":"_pthread_cond_wait","symbolLocation":984,"imageIndex":10},{"imageOffset":8518156,"imageIndex":0},{"imageOffset":1306440,"imageIndex":0},{"imageOffset":9076200,"imageIndex":0},{"imageOffset":9073768,"imageIndex":0},{"imageOffset":9067728,"imageIndex":0},{"imageOffset":8520064,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":4319427,"frames":[{"imageOffset":21412,"symbol":"__recvfrom","symbolLocation":8,"imageIndex":4},{"imageOffset":9077916,"imageIndex":0},{"imageOffset":9073960,"imageIndex":0},{"imageOffset":1293316,"imageIndex":0},{"imageOffset":1326032,"imageIndex":0},{"imageOffset":10547060,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":12},{"value":0},{"value":0},{"value":0},{"value":256},{"value":0},{"value":4385752168},{"value":2142605284},{"value":0},{"value":0},{"value":1923746859399671835},{"value":1923729258623690887},{"value":684032},{"value":15},{"value":29},{"value":8745636856},{"value":0},{"value":12},{"value":34666042448},{"value":34666042400},{"value":12},{"value":40},{"value":34682239424},{"value":48},{"value":9223372036854775799},{"value":3},{"value":34801664432}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4385752220},"cpsr":{"value":536875008},"fp":{"value":6136638624},"sp":{"value":6136638592},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6900118436},"far":{"value":0}}},{"triggered":true,"id":4319452,"threadState":{"x":[{"value":34772566092},{"value":34772566872},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":390},{"value":0},{"value":34772566872},{"value":780},{"value":65535},{"value":34772566092},{"value":0},{"value":4383291680},{"value":34772566092},{"value":0},{"value":0},{"value":0},{"value":780},{"value":34772566092},{"value":780},{"value":0},{"value":0},{"value":4383291680},{"value":0},{"value":0},{"value":0},{"value":390}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4383291304},"cpsr":{"value":4096},"fp":{"value":6092481824},"sp":{"value":6092481712},"esr":{"value":2449473606,"description":"(Data Abort) byte write Translation fault"},"pc":{"value":4383291952,"matchesCrashFrame":1},"far":{"value":0}},"frames":[{"imageOffset":6617648,"imageIndex":0},{"imageOffset":6617000,"imageIndex":0},{"imageOffset":6576128,"imageIndex":0},{"imageOffset":7458652,"imageIndex":0},{"imageOffset":8067168,"imageIndex":0},{"imageOffset":8032044,"imageIndex":0},{"imageOffset":8031844,"imageIndex":0},{"imageOffset":8436736,"imageIndex":0},{"imageOffset":8454696,"imageIndex":0},{"imageOffset":8457340,"imageIndex":0},{"imageOffset":8459892,"imageIndex":0},{"imageOffset":8060700,"imageIndex":0},{"imageOffset":8390564,"imageIndex":0},{"imageOffset":1774176,"imageIndex":0},{"imageOffset":1773068,"imageIndex":0},{"imageOffset":1437420,"imageIndex":0},{"imageOffset":1426316,"imageIndex":0},{"imageOffset":1326032,"imageIndex":0},{"imageOffset":10547060,"imageIndex":0},{"imageOffset":27656,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7080,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]}],
"usedImages" : [
"source" : "P",
"arch" : "arm64",
"base" : 4376674304,
"CFBundleShortVersionString" : "8.3.0",
"CFBundleIdentifier" : "com.garmin.connectiq.simulator",
"size" : 17596416,
"uuid" : "dcfc72f9-28ac-3626-8257-1cdc8d881c27",
"path" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
"name" : "simulator",
"CFBundleVersion" : "8.3.0"
"source" : "P",
"arch" : "arm64e",
"base" : 4400594944,
"size" : 49152,
"uuid" : "f8bd9069-8c4f-37ea-af9a-2b1060f54e4f",
"path" : "\/usr\/lib\/libobjc-trampolines.dylib",
"name" : "libobjc-trampolines.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 4798529536,
"CFBundleShortVersionString" : "341.11",
"CFBundleIdentifier" : "com.apple.AGXMetal13-3",
"size" : 7651328,
"uuid" : "bfb2418e-640c-30a5-afde-569c93fb8ae5",
"path" : "\/System\/Library\/Extensions\/AGXMetal13_3.bundle\/Contents\/MacOS\/AGXMetal13_3",
"name" : "AGXMetal13_3",
"CFBundleVersion" : "341.11"
"source" : "P",
"arch" : "arm64e",
"base" : 4821712896,
"CFBundleShortVersionString" : "1.0",
"CFBundleIdentifier" : "com.apple.AppleMetalOpenGLRenderer",
"size" : 409600,
"uuid" : "7fba6cd5-06ae-37aa-aa67-580c920ea69d",
"path" : "\/System\/Library\/Extensions\/AppleMetalOpenGLRenderer.bundle\/Contents\/MacOS\/AppleMetalOpenGLRenderer",
"name" : "AppleMetalOpenGLRenderer",
"CFBundleVersion" : "1"
"source" : "P",
"arch" : "arm64e",
"base" : 6900097024,
"size" : 246944,
"uuid" : "9fe7c84d-0c2b-363f-bee5-6fd76d67a227",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 6900633600,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 5532352,
"uuid" : "3c4a3add-9e48-33da-82ee-80520e6cbe3b",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "4109.1.401"
"source" : "P",
"arch" : "arm64e",
"base" : 7112814592,
"CFBundleShortVersionString" : "2.1.1",
"CFBundleIdentifier" : "com.apple.HIToolbox",
"size" : 3155968,
"uuid" : "9ab64c08-0685-3a0d-9a7e-83e7a1e9ebb4",
"path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
"name" : "HIToolbox"
"source" : "P",
"arch" : "arm64e",
"base" : 6972235776,
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 24300448,
"uuid" : "3c0949bb-e361-369a-80b7-17440eb09e98",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2685.20.119"
"source" : "P",
"arch" : "arm64e",
"base" : 6896373760,
"size" : 651108,
"uuid" : "b50f5a1a-be81-3068-92e1-3554f2be478a",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"source" : "P",
"arch" : "arm64e",
"base" : 6900346880,
"size" : 51900,
"uuid" : "e95973b8-824c-361e-adf4-390747c40897",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 6899384320,
"size" : 601684,
"uuid" : "b29f2164-26b0-3016-a871-82de5a4637ff",
"path" : "\/usr\/lib\/libc++.1.dylib",
"name" : "libc++.1.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 7457972224,
"CFBundleShortVersionString" : "21622",
"CFBundleIdentifier" : "com.apple.JavaScriptCore",
"size" : 28438144,
"uuid" : "c79071c9-db50-3264-a316-94abd0d3b9a9",
"path" : "\/System\/Library\/Frameworks\/JavaScriptCore.framework\/Versions\/A\/JavaScriptCore",
"name" : "JavaScriptCore",
"CFBundleVersion" : "21622.2.11.11.9"
"source" : "P",
"arch" : "arm64e",
"base" : 7593164800,
"CFBundleIdentifier" : "com.apple.WebKit",
"size" : 22128832,
"uuid" : "3b55482a-efe2-35a7-b1c9-3f41a823a30b",
"path" : "\/System\/Library\/Frameworks\/WebKit.framework\/Versions\/A\/WebKit",
"name" : "WebKit",
"sharedCache" : {
"base" : 6895288320,
"size" : 5609635840,
"uuid" : "b69ff43c-dbfd-3fb1-b4fe-a8fe32ea1062"
"vmSummary" : "ReadOnly portion of Libraries: Total=1.8G resident=0K(0%) swapped_out_or_unallocated=1.8G(100%)\nWritable regions: Total=4.7G written=1828K(0%) resident=948K(0%) swapped_out=880K(0%) unallocated=4.7G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 256K 2 \nActivity Tracing 256K 1 \nAttributeGraph Data 1024K 1 \nCG image 3248K 14 \nCG raster data 2352K 6 \nColorSync 48K 3 \nCoreAnimation 1984K 72 \nCoreGraphics 32K 2 \nCoreUI image data 4112K 32 \nDispatch continuations 64.0M 1 \nFoundation 48K 2 \nImage IO 128K 2 \nKernel Alloc Once 32K 1 \nMALLOC 266.9M 65 \nMALLOC guard page 3840K 4 \nSTACK GUARD 56.5M 33 \nStack 26.7M 87 \nVM_ALLOCATE 87.6M 279 \nVM_ALLOCATE (reserved) 4.0G 1 reserved VM address space (unallocated)\nWebKit Malloc 192.1M 7 \nWebKit Malloc (reserved) 64.0M 1 reserved VM address space (unallocated)\n__AUTH 5849K 655 \n__AUTH_CONST 88.8M 1039 \n__CTF 824 1 \n__DATA 31.5M 988 \n__DATA_CONST 33.8M 1047 \n__DATA_DIRTY 8837K 899 \n__FONT_DATA 2352 1 \n__GLSLBUILTINS 5174K 1 \n__INFO_FILTER 8 1 \n__LINKEDIT 595.4M 5 \n__OBJC_RO 78.3M 1 \n__OBJC_RW 2567K 1 \n__TEXT 1.2G 1070 \n__TPRO_CONST 128K 2 \nmapped file 636.0M 66 \npage table in kernel 948K 1 \nshared memory 928K 16 \n=========== ======= ======= \nTOTAL 7.4G 6410 \nTOTAL, minus reserved VM space 3.4G 6410 \n",
"legacyInfo" : {
"threadTriggered" : {
"logWritingSignature" : "654b9e3570b779fba71e64d89dd031a443403032",
"trialInfo" : {
"rollouts" : [
"rolloutId" : "6761d0c9df60af01adb250fb",
"factorPackIds" : [
"deploymentId" : 240000009
"rolloutId" : "68095e8ecb2a9d1eaa8463c9",
"factorPackIds" : [
"68bf4eacb556ea03e19aed49"
"deploymentId" : 240000008
"experiments" : [
Model: MacBookAir10,1, BootROM 13822.41.1, proc 8:4:4 processors, 8 GB, SMC
Graphics: Apple M1, Apple M1, Built-In
Display: Color LCD, 2560 x 1600 Retina, Main, MirrorOff, Online
Memory Module: LPDDR4, Hynix
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4378), wl0: Jul 11 2025 19:42:21 version 18.20.480.0.7.8.186 FWID 01-6e662c81
IO80211_driverkit-1530.16 "IO80211_driverkit-1530.16" Oct 10 2025 22:56:35
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Thunderbolt Bus: MacBook Air, Apple Inc.
Parents
  • Note that since firmware version 12.21 for the instinct3 (45mm, 50mm and crossover), the 3 image formats were added in.
    Using anything other than "default" as the packingFormat will make these watches crash when using drawBitmap2. This will cause issues if you're relying on the compiler to switch the packingFormat to "default" on devices that don't support it.
Comment
Children
No Data
