Given this code:
import Toybox.Test;
import Toybox.Lang;
module LocalResolution {
module AX {
module BX {
const K = 1;
import LocalResolution.AX.BX;
module CX {
module BX {
const K = 1001;
class X {
const K = 2001;
function foo() as Number {
var BX = new X();
return BX.K; // should be X.K
(:test)
function testImport(logger as Logger) as Boolean {
var k = CX.foo();
if (k != 2001) {
logger.debug("Oops - found the wrong k: " + k.toString());
return false;
return true;
The test passes with compilers up to 4.1.4 (non-beta). With Compiler2 Beta, it fails, because foo() returns 1.
Without the import, it works. But with the import, even though BX is a local variable, BX.K resolves to LocalResolution.AX.BX.K.
The *typechecker* in earlier versions of the compiler thought this is how things worked. But the runtime disagreed (and I've reported that as a type checker bug previously). Apparently, in this release, you've changed the runtime to match the type checker (I guess it can't really be the runtime; the compiler must be transforming BX into something more explicit, like $.LocalResolution.AX.BX. Or maybe its optimizing the constant away, even without a -O flag). The net result though, is that the runtime behavior has changed.
This seems like a serious mistake. If adding an import can cause an existing local variable to resolve to the import instead, all hell breaks loose. The import could be at global scope, in a different file, for example.
