Acknowledged
CIQQA-3581
Casting Float to Number does not yield Number
This code:
var myFloat = 5.0;
var myNumber = myFloat as Number;
var mod = myNumber % 1;
Compiles without warnings, but crashes at runtime with:
Error: Unhandled Exception
Exception: UnexpectedTypeException: Expected Number/Long, given Number/Float
As far as I can tell:
  • this behavior is undocumented
  • the types "Number/Long" and "Number/Float" are undocumented
  • the effects of casting numeric types are undocumented
Consequently I'm not sure how to characterize this bug. If it's expected, this is a documentation bug. If it's not expected, this is a runtime and/or compiler bug.
I read the relevant section on "type casting" in the SDK docs. I've reproduced the totality of the documentation on type casting here:
The as keyword can also be used in an expression to type cast a value to another type. This can be useful if the type is not clear to the type system.
This, unfortunately, does not help very much.
Tested on Descent G1 & G2 simulators
SDK 8.3.0
Parents
  • - Therefore, the best policy is to use type check level two or three, if you want the type check system to be legit useful
    - To set the type check level for all projects: CTRL-SHIFT-P / CMD-SHIFT-P > Open User Settings > [Search] Monkey C > Monkey C: Type Check Level
    - To set the type check level for the current project, add the following line to monkey.jungle:
    Sorry for the code screenshots, but the forum is blocking attempts to post code, as it has been doing for about a year now
Comment
Children
No Data
