This code:
var myFloat = 5.0;
var myNumber = myFloat as Number;
var mod = myNumber % 1;
Compiles without warnings, but crashes at runtime with:
Error: Unhandled Exception
Exception: UnexpectedTypeException: Expected Number/Long, given Number/Float
As far as I can tell:
- this behavior is undocumented
- the types "Number/Long" and "Number/Float" are undocumented
- the effects of casting numeric types are undocumented
Consequently I'm not sure how to characterize this bug. If it's expected, this is a documentation bug. If it's not expected, this is a runtime and/or compiler bug.
I read the relevant section on "type casting" in the SDK docs. I've reproduced the totality of the documentation on type casting here:
The
askeyword can also be used in an expression to type cast a value to another type. This can be useful if the type is not clear to the type system.
This, unfortunately, does not help very much.
Tested on Descent G1 & G2 simulators
SDK 8.3.0
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
