Acknowledged
over 1 year ago
Cannot upload datafield to connectiq store
Hi:
I'd like to update my data field to fix some bugs, but always failed with "undefined" error. Can somebody help on it? Thanks.
I cannot upload the error snapshot because "The selected file is not allowed due to file quota restrictions."
  • Had the same issue. Fixed by using the makefile example from Linkettt:
    github.com/.../main
  • The IQ file has been sent. Do you received it? Is there any update?
    I'd like upload a brand new datafield and encountered the same issue. Thanks.
  • Hi Brandon
    Thanks a lot for your prompt response. Just sent the image and please check it. This is the test result as you suggested, thanks.
    * Make sure the file name on the file system matches what's in the submission form.
    [yp] the file name is AnalogPanel-1.3.8.iq, it works on my other watchface app.
    * Make sure the file has not moved or been renamed after you choose the file.
    [yp] No, it's not moved or renamed.
    * Try renaming the IQ file itself.
    [yp] It doesn't work by renaming.
    * Rebuild the app with a new manifest ID.
    [yp] I've try to add a new app with new manifest ID and it has the same issue.
  • I just tested this with one of our test data field apps, and didn't encounter this error. Does this problem persist, and if so, can you provide the IQ file you're attempting to upload? You can email it to [email protected] and reference this forum thread.
    I don't see anything wrong in the image you included, but the error appears to be a form validation error so perhaps it's related to the file name itself. A few things to try:
    • Make sure the file name on the file system matches what's in the submission form.
    • Make sure the file has not moved or been renamed after you choose the file.
    • Try renaming the IQ file itself.
    • Rebuild the app with a new manifest ID.
