Acknowledged
Cannot reference Barrel string resources in Watch Face settings.xml
According to Monkey Barrel documentation, barrel resources should be accessible in the project via the @IconLibrary.Drawables.myIcon notation.  This suggests @MyBarrel.Strings.myString would be a valid way to reference a string from the app.  This isn't working as expected when referenced inside settings.xml for the Watch Face using this barrel.
Like user  wrote in "How to reference barrel resources from app xml", I am attempting to reference a barrel's String resources inside my Watch Face's settings.XML.   I'd expect to see the actual strings, but instead I see the references.
See screenshots:
https://www.dropbox.com/s/tei8puk0hcqx6oo/Screen%20Shot%202022-12-29%20at%201.05.39%20PM.png?dl=0
https://www.dropbox.com/s/mtkhvac605gz1hh/Screen%20Shot%202022-12-29%20at%201.05.58%20PM.png?dl=0
  • No, the message is from when using a non-resource string to show you what the 'required' format it returns is. I used the barrel version after, it gives no errors, but does not load the string, just gives blanks.
  • From the error message it looks like it's a bug in your XML, which you haven't included so we can only guess
  • FYI, this bug is still not fixed 4 years later. Error statements even refer you to use the format that specifically doesn't work.
    Invalid Strings resource reference 'Blue' in attribute 'label'. Use formats: '@Strings.<resource id>' or '@<barrel name>.Strings.<resource id>' (if the Monkey Barrel dependency is defined).
  • Hi Gavriel, I tried switching it as you suggested.  The same behavior happened -- the string from the barrel wasn't recognized & filled when I used it as the title for the setting.  So it appears that it's not possible to use barrel string resources in either the <listEntry> items or the "title" tag of <setting> items.
    The other switch you suggested does work -- that's normal behavior that is working as expected: the settings.xml can reference string resources from inside the same project.
    Also, the upload link isn't appearing anymore in this reply editor, so I have to share dropbox links again:
    Image showing the settings.xml updated to be: <setting propertyKey="@Properties.AnalogGaugeMetric2" title="@CommonData.Strings.SENSOR_O2">
    https://capture.dropbox.com/AKduGpFVtXUi6gys
    Image showing the result in the simulator:
    https://capture.dropbox.com/nAEY8ZAZ8cULRzWT
    Image showing the lack of upload link in the "insert image" in this reply editor:
    https://capture.dropbox.com/Gdr6V3DVVYAtFeTc
  • I don't think it's a bug, I think you're trying to use the reference where it's not supposed to be used. Try if you switch @Strings.MiniGaugeBottomCenter... to one of the @CommonData.Strings.SENSOR_O2. If it will display the correct string then I am right, if not then probably you, but then as a second test also do the opposite: switch @CommonData.Strings.SENSOR_O2 to @Strings.MiniGaugeBottomCenter....
