Acknowledged
CIQQA-4695
Can’t add sensors to simulator
In simulator, Settings -> Manage sensors -> Add
Nothing shows up. Am using a Garmin ANT+ antenna that I use with my Tacx Neo, or a CooSpo USB dongle. In both cases trying to add a sensor results up in ‘No sensors four. Retry?’ message. Retrying achieves nothing.
Have tried to pair a Garmin HRM dual (ANT+/BLE), a Varia radar/rear light and a Varia front light, can’t add any of them.
Either I’m doing something wrong or the simulator is broken. If it’s the first case then surely some instructions should be supplied, or if it’s the latter case then this really needs fixing ASAP as interacting with the sensors is a pretty basic requirement.
Parents
  • Are you trying to simulate data from sensors that are normally paired to the device?  You mentioned a HRM.  If that's the case, record an activity on your Garmin with the sensors you use, and them in the sim, play back the recorded fit file
    Simulation>Activity Data>FIT/GPX playback file
Comment
Children
No Data
