Acknowledged
CIQQA-4695
Can’t add sensors to simulator
In simulator, Settings -> Manage sensors -> Add
Nothing shows up. Am using a Garmin ANT+ antenna that I use with my Tacx Neo, or a CooSpo USB dongle. In both cases trying to add a sensor results up in ‘No sensors four. Retry?’ message. Retrying achieves nothing.
Have tried to pair a Garmin HRM dual (ANT+/BLE), a Varia radar/rear light and a Varia front light, can’t add any of them.
Either I’m doing something wrong or the simulator is broken. If it’s the first case then surely some instructions should be supplied, or if it’s the latter case then this really needs fixing ASAP as interacting with the sensors is a pretty basic requirement.
Parents
  • In my particular use case I want to get a list of all paired and active sensors and then get a variety of information from each one for display on a data field. I need to use the simulator to get access to the sensors without the tedium of loading an app to the head unit.
Comment
Children
No Data
