I'm using resource overrides for some devices to override layouts. I am using text-areas in my layout file and for devices that don't support text-areas I create device specific layout files (such as the vivoactive 3). It works fine in the simulator but when I export my project I get build errors, it seems it builds all layout files for each device. I expected that only the device specific layout file would be built. Did I misunderstand the concept?
Here is my file structure
resources/layouts/layout.xml resources-round-240x240/layouts/layout.xml resources-vivoactive3/layouts/layout.xml
Build errors:
ERROR: vivoactive3: C:\Garmin-projects\Face\resources-round-240x240\layouts\layout.xml:9: TextArea is not supported by device 'vivoactive3'.
ERROR: vivoactive3: C:\Garmin-projects\Face\resources-round-240x240\layouts\layout.xml:16: TextArea is not supported by device 'vivoactive3'.
ERROR: vivoactive3: C:\Garmin-projects\Face\resources\layouts\layout.xml:12: TextArea is not supported by device 'vivoactive3'.
ERROR: vivoactive3: C:\Garmin-projects\Face\resources\layouts\layout.xml:20: TextArea is not supported by device 'vivoactive3'.
ERROR: Failed to export application for device id: 'vivoactive3'.
running SDK: 4.2.3
Visual Code with MonkeyC v. 1.0.8
AndyBrt
in reply to Fsallstrom
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
AndyBrt
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
