Acknowledged
[BUGS] MacOS simulator bugs
  1. Sim crashes randomly, usually if its been running for a while (over an hour?).  Happens when I leave my Mac and return to a crashed Sim
  2. VS Code debugger cannot connect to the Sim.  Usually happens after several runs of an app.  Frequently happens after switching devices
  3. Cannot click on time field in Time Simulation dialog.  Must TAB to it.
  4. Crashes when clicking on Save in Activity Data dialog
  5. Scalable fonts are drawn in wrong scale when switch devices (FR265 to FR265s for example).  Here is my font selection call: var font = Graphics.getVectorFont({:face => ["RobotoCondensedBold", "RobotoCondensedRegular"], :size => size});  See attached for the result.
These bugs make testing on all devices in the sim painfully slow.
Pete
Parents
    Translated Report (Full Report Below)
    Process: simulator [10030]
    Path: /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
    Identifier: com.garmin.connectiq.simulator
    Version: 6.4.0 (6.4.0)
    Code Type: X86-64 (Translated)
    Parent Process: launchd [1]
    User ID: 501
    Date/Time: 2023-12-18 08:00:13.0421 -0800
    OS Version: macOS 14.1.2 (23B92)
    Report Version: 12
    Anonymous UUID: 5A18F4F2-35C0-936C-34A5-D2F176301C89
    Sleep/Wake UUID: D0E52FB6-08F0-434D-8283-D55F2E0AF9AE
    Time Awake Since Boot: 760000 seconds
    Time Since Wake: 9231 seconds
    System Integrity Protection: enabled
    Notes:
    PC register does not match crashing frame (0x0 vs 0x7FF80EA7CA14)
    Crashed Thread: 13 parse main
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
    Exception Codes: 0x0000000000000001, 0x0000000000000000
    Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
    Terminating Process: exc handler [10030]
    VM Region Info: 0 is not in any region. Bytes before following region: 4307292160
    REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
    UNUSED SPACE AT START
    __TEXT 100bc1000-101b8d000 [ 15.8M] r-x/r-x SM=COW ...cOS/simulator
    Error Formulating Crash Report:
    Thread 0:: Dispatch queue: com.apple.main-thread
    0 ??? 0x7ff89ef02a78 ???
    1 libsystem_kernel.dylib 0x7ff80ea0db0a _kernelrpc_mach_port_type_trap + 10
    2 libsystem_kernel.dylib 0x7ff80ea0fd3e mach_port_type + 24
    3 CoreFoundation 0x7ff80eb002a0 CFRunLoopAddSource + 167
    4 HIToolbox 0x7ff819861c83 _HLTBAddEventSourceToMode + 59
    5 AppKit 0x7ff812097699 _DPSNextEvent + 388
    6 AppKit 0x7ff81298b348 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1304
    7 AppKit 0x7ff8122828a0 -[NSWindow(NSEventRouting) trackEventsMatchingMask:timeout:mode:handler:] + 261
    8 AppKit 0x7ff8122817b1 -[NSDragEventTracker trackEvent:usingHandler:] + 889
    9 AppKit 0x7ff812280d12 NSControlTrackMouse + 1459
    10 AppKit 0x7ff81228073b -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 125
    11 AppKit 0x7ff8123edfd0 -[NSSliderCell trackMouse:inRect:ofView:untilMouseUp:] + 119
    12 AppKit 0x7ff81227f9f8 -[NSControl mouseDown:] + 666
    13 simulator 0x10165160e 0x100bc1000 + 11077134
    14 simulator 0x101643a12 0x100bc1000 + 11020818
    15 AppKit 0x7ff81227e39d -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 4580
    16 AppKit 0x7ff8121f6fca -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 404
    17 AppKit 0x7ff8121f6c1b -[NSWindow(NSEventRouting) sendEvent:] + 345
    18 simulator 0x10163f61b 0x100bc1000 + 11003419
    19 AppKit 0x7ff8129895f6 -[NSApplication(NSEventRouting) sendEvent:] + 346
    20 simulator 0x1015b04b2 0x100bc1000 + 10417330
    21 AppKit 0x7ff81254a0df -[NSApplication _handleEvent:] + 65
    22 AppKit 0x7ff812088e1f -[NSApplication run] + 640
    23 simulator 0x1016354aa 0x100bc1000 + 10962090
    24 simulator 0x101534fbd 0x100bc1000 + 9912253
    25 simulator 0x1014a6b2e 0x100bc1000 + 9329454
    26 simulator 0x101479443 0x100bc1000 + 9143363
    27 simulator 0x1015f1a8a 0x100bc1000 + 10685066
    28 simulator 0x1014dbc88 0x100bc1000 + 9546888
    29 simulator 0x100c035b2 0x100bc1000 + 271794
    30 dyld 0x20212c3a6 start + 1942
    Thread 1:: com.apple.rosetta.exceptionserver
    0 runtime 0x7ff7ffbce294 0x7ff7ffbca000 + 17044
    Thread 2:: com.apple.NSEventThread
    1 libsystem_kernel.dylib 0x7ff80ea0da6e mach_msg2_trap + 10
    2 libsystem_kernel.dylib 0x7ff80ea1be7a mach_msg2_internal + 84
    3 libsystem_kernel.dylib 0x7ff80ea14b92 mach_msg_overwrite + 653
    4 libsystem_kernel.dylib 0x7ff80ea0dd5f mach_msg + 19
    5 CoreFoundation 0x7ff80eb27b49 __CFRunLoopServiceMachPort + 143
    6 CoreFoundation 0x7ff80eb265bc __CFRunLoopRun + 1371
    7 CoreFoundation 0x7ff80eb25a99 CFRunLoopRunSpecific + 557
    8 AppKit 0x7ff8121f4a00 _NSEventThread + 122
    9 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    10 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 3:: TSK bkgd
    1 libsystem_kernel.dylib 0x7ff80ea1060e __psynch_cvwait + 10
    2 libsystem_pthread.dylib 0x7ff80ea4d76b _pthread_cond_wait + 1211
    3 simulator 0x10134d96a 0x100bc1000 + 7915882
    4 simulator 0x10134cc22 0x100bc1000 + 7912482
    5 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    6 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 4:: NFM_Region_0
    4 simulator 0x1013c2043 0x100bc1000 + 8392771
    5 simulator 0x10134cc56 0x100bc1000 + 7912534
    6 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    7 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 5:: IOPAppMain
    4 simulator 0x1010bf515 0x100bc1000 + 5235989
    5 simulator 0x10134cc40 0x100bc1000 + 7912512
    Thread 6:: ant_main
    2 libsystem_pthread.dylib 0x7ff80ea4d79c _pthread_cond_wait + 1260
    3 simulator 0x10134c700 0x100bc1000 + 7911168
    4 simulator 0x10134d96a 0x100bc1000 + 7915882
    5 simulator 0x1010946b5 0x100bc1000 + 5060277
    6 simulator 0x10134cc40 0x100bc1000 + 7912512
    7 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    8 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 7:: GPS main
    Thread 8:: SNS main
    Thread 9:: fit activity
    4 simulator 0x1010fe962 0x100bc1000 + 5495138
    Thread 10:: ftm main
    5 simulator 0x10110dfdf 0x100bc1000 + 5558239
    Thread 11:: TVM main
    5 simulator 0x1012f5cd5 0x100bc1000 + 7556309
    Thread 12:: TVM defrag
    Thread 13 Crashed:: parse main
    0 libsystem_platform.dylib 0x7ff80ea7ca14 _platform_memmove$VARIANT$Rosetta + 340
    1 simulator 0x100be1218 0x100bc1000 + 131608
    2 simulator 0x100be2a43 0x100bc1000 + 137795
    3 simulator 0x10134cc40 0x100bc1000 + 7912512
    4 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    5 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 14:: GPX archive trk
    4 simulator 0x1013d2fa5 0x100bc1000 + 8462245
    Thread 15:: URM Main
    4 simulator 0x1010e1d25 0x100bc1000 + 5377317
    Thread 16:: mma sql bkg
    Thread 17:: TLG main
    5 simulator 0x1013d2dce 0x100bc1000 + 8461774
    6 simulator 0x10134cc56 0x100bc1000 + 7912534
    Thread 18:: libcurl Async H
    4 simulator 0x1010db7b5 0x100bc1000 + 5351349
    Thread 19:: Download Manage
    4 simulator 0x1010ddd05 0x100bc1000 + 5360901
    Thread 20:: Shell main
    1 libsystem_kernel.dylib 0x7ff80ea1485e __accept + 10
    2 simulator 0x1013cdca2 0x100bc1000 + 8440994
    3 simulator 0x1013caaa7 0x100bc1000 + 8428199
    4 simulator 0x10134cc40 0x100bc1000 + 7912512
    Thread 21:
    3 libc++.1.dylib 0x7ff80e9853c2 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18
    4 simulator 0x100c8c7c2 0x100bc1000 + 833474
    5 simulator 0x100c8c6bf 0x100bc1000 + 833215
    6 simulator 0x100c8c562 0x100bc1000 + 832866
    Thread 22:
    2 simulator 0x100cef71c 0x100bc1000 + 1238812
    3 simulator 0x100cc36ec 0x100bc1000 + 1058540
    4 simulator 0x101547f6c 0x100bc1000 + 9989996
    5 simulator 0x1015479ff 0x100bc1000 + 9988607
    Thread 23:: Shell handler
    3 simulator 0x10134c49c 0x100bc1000 + 7910556
    4 simulator 0x100ceec84 0x100bc1000 + 1236100
    5 simulator 0x1013cda1a 0x100bc1000 + 8440346
    6 simulator 0x1013ccf73 0x100bc1000 + 8437619
    7 simulator 0x1013cb407 0x100bc1000 + 8430599
    8 simulator 0x10134cc40 0x100bc1000 + 7912512
    Thread 24:
    1 libsystem_kernel.dylib 0x7ff80ea11176 __recvfrom + 10
    2 simulator 0x1013ce081 0x100bc1000 + 8441985
    3 simulator 0x1013cd012 0x100bc1000 + 8437778
    4 simulator 0x100cec30a 0x100bc1000 + 1225482
    5 simulator 0x100cf3c5f 0x100bc1000 + 1256543
    6 simulator 0x101547f6c 0x100bc1000 + 9989996
    7 simulator 0x1015479ff 0x100bc1000 + 9988607
    8 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    9 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 25:
    0 simulator 0x10115b9be 0x100bc1000 + 5876158
    1 simulator 0x10112f141 0x100bc1000 + 5693761
    2 simulator 0x10112ede2 0x100bc1000 + 5692898
    3 simulator 0x101161936 0x100bc1000 + 5900598
    4 simulator 0x101165091 0x100bc1000 + 5914769
    5 simulator 0x101165d66 0x100bc1000 + 5918054
    6 simulator 0x10111df75 0x100bc1000 + 5623669
    7 simulator 0x1011da01e 0x100bc1000 + 6393886
    8 simulator 0x1011d9663 0x100bc1000 + 6391395
    9 simulator 0x1011d8f7a 0x100bc1000 + 6389626
    10 simulator 0x1011d9072 0x100bc1000 + 6389874
    11 simulator 0x1012e307b 0x100bc1000 + 7479419
    12 simulator 0x1012dc85b 0x100bc1000 + 7452763
    13 simulator 0x101339e1e 0x100bc1000 + 7835166
    14 simulator 0x10133d1ff 0x100bc1000 + 7848447
    15 simulator 0x10133d91b 0x100bc1000 + 7850267
    16 simulator 0x10133e62a 0x100bc1000 + 7853610
    17 simulator 0x1012e17ee 0x100bc1000 + 7473134
    18 simulator 0x10132fc98 0x100bc1000 + 7793816
    19 simulator 0x100d4a31d 0x100bc1000 + 1610525
    20 simulator 0x100d0b9db 0x100bc1000 + 1354203
    21 simulator 0x100d4bdf2 0x100bc1000 + 1617394
    22 simulator 0x100d09afe 0x100bc1000 + 1346302
    23 simulator 0x100cf3c5f 0x100bc1000 + 1256543
    24 simulator 0x101547f6c 0x100bc1000 + 9989996
    25 simulator 0x1015479ff 0x100bc1000 + 9988607
    26 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    27 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 26:: com.apple.coreanimation.render-server
    5 QuartzCore 0x7ff8174d7150 CA::Render::Server::server_thread(void*) + 534
    6 QuartzCore 0x7ff8174d6f29 thread_fun(void*) + 25
    Thread 27:: WebCore: Scrolling
    8 CoreFoundation 0x7ff80eba0889 CFRunLoopRun + 40
    9 JavaScriptCore 0x7ff82bca4872 WTF::Detail::CallableWrapper<WTF::RunLoop::create(char const*, WTF::ThreadType, WTF::Thread::QOS)::$_1, void>::call() + 82
    10 JavaScriptCore 0x7ff82bcbf6bd WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*) + 237
    11 JavaScriptCore 0x7ff82baafba9 WTF::wtfThreadEntryPoint(void*) + 9
    12 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    13 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 28:
    0 runtime 0x7ff7ffbec94c 0x7ff7ffbca000 + 141644
    Thread 29:
    Thread 30:
    Thread 13 crashed with X86 Thread State (64-bit):
    rax: 0x000000003ee11dbb rbx: 0xffffffffffffffff rcx: 0x0000000000000020 rdx: 0x0000000000003568
    rdi: 0x0000000000000000 rsi: 0x00007fd071011c68 rbp: 0x00000003075a7b30 rsp: 0x00000003075a7b00
    r8: 0x0000000000739402 r9: 0x000001b7ffffffff r10: 0xffffffffffffffff r11: 0xffffffffffffffff
    r12: 0x0000006a000059c8 r13: 0x3ee11dbb3ee11dbb r14: 0xa934edf521e4611c r15: 0x7fffffff00000000
    rip: <unavailable> rfl: 0x0000000000000287
    tmp0: 0x00007ff89f453144 tmp1: 0x0000000000019267 tmp2: 0x000000012079c670
    Binary Images:
    0x202126000 - 0x2021c5fff dyld (*) <d5406f23-6967-39c4-beb5-6ae3293c7753> /usr/lib/dyld
    0x12ea24000 - 0x12f3b7fff com.apple.audio.codecs.Components (7.0) <026b9761-d7e5-392e-bd22-73638035931b> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
    0x11df22000 - 0x11df91fff com.apple.AppleMetalOpenGLRenderer (1.0) <e8731326-3e64-3623-8b4f-7b010926a559> /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer
    0x10bc31000 - 0x10bc40fff libobjc-trampolines.dylib (*) <7e101877-a6ff-3331-99a3-4222cb254447> /usr/lib/libobjc-trampolines.dylib
    0x7ff7ffbca000 - 0x7ff7ffbf9fff runtime (*) <2c5acb8c-fbaf-31ab-aeb3-90905c3fa905> /usr/libexec/rosetta/runtime
    0x10b509000 - 0x10b55cfff libRosettaRuntime (*) <a61ec9e9-1174-3dc6-9cdb-0d31811f4850> /Library/Apple/*/libRosettaRuntime
    0x100bc1000 - 0x101b8cfff com.garmin.connectiq.simulator (6.4.0) <85059f24-2407-3ef8-b459-b1bc3ac1586d> /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
    0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
    0x7ff80ea0c000 - 0x7ff80ea46ff7 libsystem_kernel.dylib (*) <4df0d732-7fc4-3200-8176-f1804c63f2c8> /usr/lib/system/libsystem_kernel.dylib
    0x7ff80eaac000 - 0x7ff80ef44ffc com.apple.CoreFoundation (6.9) <4d842118-bb65-3f01-9087-ff1a2e3ab0d5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7ff81985d000 - 0x7ff819af8ff4 com.apple.HIToolbox (2.1.1) <06bf0872-3b34-3c7b-ad5b-7a447d793405> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7ff812059000 - 0x7ff81345effb com.apple.AppKit (6.9) <27fed5dd-d148-3238-bc95-1dac5dd57fa1> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7ff80ea47000 - 0x7ff80ea52fff libsystem_pthread.dylib (*) <c64722b0-e96a-3fa5-96c3-b4beaf0c494a> /usr/lib/system/libsystem_pthread.dylib
    0x7ff80ea77000 - 0x7ff80ea80fff libsystem_platform.dylib (*) <c94f952c-2787-30d2-ab77-ee474abd88d6> /usr/lib/system/libsystem_platform.dylib
    0x7ff80e974000 - 0x7ff80e9f2fff libc++.1.dylib (*) <b0f79a73-e705-38c8-a162-2465ed2adfaa> /usr/lib/libc++.1.dylib
    0x7ff81748e000 - 0x7ff817835ff9 com.apple.QuartzCore (1.11) <a1fb38a4-9d16-3fa7-ac42-be6f87a69a7a> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7ff82baad000 - 0x7ff82d690fea com.apple.JavaScriptCore (19616) <c925d606-3694-3941-8463-00a074e9d65b> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    External Modification Summary:
    Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=988.0M resident=0K(0%) swapped_out_or_unallocated=988.0M(100%)
    Writable regions: Total=6.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=6.1G(100%)
    VIRTUAL REGION
    REGION TYPE SIZE COUNT (non-coalesced)
    Accelerate framework 256K 2
    Activity Tracing 256K 1
    CG image 1720K 45
    CG raster data 1976K 4
    ColorSync 264K 34
    CoreAnimation 5240K 151
    CoreGraphics 16K 3
    CoreImage 16K 1
    CoreUI image data 3444K 26
    Dispatch continuations 96.0M 1
    Foundation 16K 1
    Kernel Alloc Once 8K 1
    MALLOC 1.7G 94
    MALLOC guard page 384K 24
    Rosetta Arena 4096K 2
    Rosetta Generic 1936K 481
    Rosetta IndirectBranch 2048K 1
    Rosetta JIT 128.0M 1
    Rosetta Return Stack 600K 60
    Rosetta Thread Context 600K 60
    STACK GUARD 12K 3
    Stack 23.3M 33
    Stack Guard 56.1M 27
    VM_ALLOCATE 134.6M 32
    VM_ALLOCATE (reserved) 3.9G 3 reserved VM address space (unallocated)
    WebKit Malloc 192.0M 6
    __CTF 824 1
    __DATA 42.0M 666
    __DATA_CONST 46.4M 447
    __DATA_DIRTY 1795K 238
    __FONT_DATA 2352 1
    __GLSLBUILTINS 5174K 1
    __LINKEDIT 181.2M 12
    __OBJC_RO 70.7M 1
    __OBJC_RW 2154K 2
    __TEXT 806.9M 683
    dyld private memory 260K 2
    mapped file 6.9G 1069
    shared memory 812K 16
    unshared pmap 12.3M 9
    TOTAL 14.2G 4245
    TOTAL, minus reserved VM space 10.3G 4245
    Full Report
    {"app_name":"simulator","timestamp":"2023-12-18 08:00:33.00 -0800","app_version":"6.4.0","slice_uuid":"85059f24-2407-3ef8-b459-b1bc3ac1586d","build_version":"6.4.0","platform":1,"bundleID":"com.garmin.connectiq.simulator","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 14.1.2 (23B92)","roots_installed":0,"name":"simulator","incident_id":"A0A6E4B9-4A59-4714-BA39-4F4683C380D5"}
    "uptime" : 760000,
    "procRole" : "Foreground",
    "version" : 2,
    "userID" : 501,
    "deployVersion" : 210,
    "modelCode" : "Mac14,10",
    "coalitionID" : 6765,
    "osVersion" : {
    "train" : "macOS 14.1.2",
    "build" : "23B92",
    "releaseType" : "User"
    "captureTime" : "2023-12-18 08:00:13.0421 -0800",
    "codeSigningMonitor" : 1,
    "incident" : "A0A6E4B9-4A59-4714-BA39-4F4683C380D5",
    "pid" : 10030,
    "translated" : true,
    "cpuType" : "X86-64",
    "roots_installed" : 0,
    "bug_type" : "309",
    "procLaunch" : "2023-12-18 07:47:05.8152 -0800",
    "procStartAbsTime" : 18252233536918,
    "procExitAbsTime" : 18271126521201,
    "procName" : "simulator",
    "procPath" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
    "bundleInfo" : {"CFBundleShortVersionString":"6.4.0","CFBundleVersion":"6.4.0","CFBundleIdentifier":"com.garmin.connectiq.simulator"},
    "storeInfo" : {"deviceIdentifierForVendor":"3D59878A-5B4A-5D19-A690-441F57ACC310","thirdParty":true},
    "parentProc" : "launchd",
    "parentPid" : 1,
    "coalitionName" : "com.garmin.connectiq.simulator",
    "crashReporterKey" : "5A18F4F2-35C0-936C-34A5-D2F176301C89",
    "codeSigningID" : "com.garmin.connectiq.simulator",
    "codeSigningTeamID" : "72ES32VZUA",
    "codeSigningFlags" : 570503953,
    "codeSigningValidationCategory" : 6,
    "codeSigningTrustLevel" : 4294967295,
    "wakeTime" : 9231,
    "sleepWakeUUID" : "D0E52FB6-08F0-434D-8283-D55F2E0AF9AE",
    "sip" : "enabled",
    "vmRegionInfo" : "0 is not in any region. Bytes before following region: 4307292160\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 100bc1000-101b8d000 [ 15.8M] r-x\/r-x SM=COW ...cOS\/simulator",
    "exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000000"},
    "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":10030},
    "vmregioninfo" : "0 is not in any region. Bytes before following region: 4307292160\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 100bc1000-101b8d000 [ 15.8M] r-x\/r-x SM=COW ...cOS\/simulator",
    "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
    "faultingThread" : 13,
    "threads" : [{"id":7574393,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":19321291},"r12":{"value":140534684373296},"rosetta":{"tmp2":{"value":140703374048574},"tmp1":{"value":140705795156552},"tmp0":{"value":18446744073709551615}},"rbx":{"value":140704503343944,"symbolLocation":0,"symbol":"mach_task_self_"},"r8":{"value":140534684823648},"r15":{"value":515},"r10":{"value":140704503343944,"symbolLocation":0,"symbol":"mach_task_self_"},"rdx":{"value":13000167520},"rdi":{"value":140534684456496},"r9":{"value":19321291},"r13":{"value":154618822656},"rflags":{"value":659},"rax":{"value":0},"rsp":{"value":65523219155002384},"r11":{"value":140703374945900,"symbolLocation":0,"symbol":"-[__NSArrayI objectAtIndex:]"},"rcx":{"value":12051},"r14":{"value":12051},"rsi":{"value":12051}},"queue":"com.apple.main-thread","frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":6922,"symbol":"_kernelrpc_mach_port_type_trap","symbolLocation":10,"imageIndex":8},{"imageOffset":15678,"symbol":"mach_port_type","symbolLocation":24,"imageIndex":8},{"imageOffset":344736,"symbol":"CFRunLoopAddSource","symbolLocation":167,"imageIndex":9},{"imageOffset":19587,"symbol":"_HLTBAddEventSourceToMode","symbolLocation":59,"imageIndex":10},{"imageOffset":255641,"symbol":"_DPSNextEvent","symbolLocation":388,"imageIndex":11},{"imageOffset":9642824,"symbol":"-[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":1304,"imageIndex":11},{"imageOffset":2267296,"symbol":"-[NSWindow(NSEventRouting) trackEventsMatchingMask:timeout:mode:handler:]","symbolLocation":261,"imageIndex":11},{"imageOffset":2262961,"symbol":"-[NSDragEventTracker trackEvent:usingHandler:]","symbolLocation":889,"imageIndex":11},{"imageOffset":2260242,"symbol":"NSControlTrackMouse","symbolLocation":1459,"imageIndex":11},{"imageOffset":2258747,"symbol":"-[NSCell trackMouse:inRect:ofView:untilMouseUp:]","symbolLocation":125,"imageIndex":11},{"imageOffset":3755984,"symbol":"-[NSSliderCell trackMouse:inRect:ofView:untilMouseUp:]","symbolLocation":119,"imageIndex":11},{"imageOffset":2255352,"symbol":"-[NSControl mouseDown:]","symbolLocation":666,"imageIndex":11},{"imageOffset":11077134,"imageIndex":6},{"imageOffset":11020818,"imageIndex":6},{"imageOffset":2249629,"symbol":"-[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:]","symbolLocation":4580,"imageIndex":11},{"imageOffset":1695690,"symbol":"-[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:]","symbolLocation":404,"imageIndex":11},{"imageOffset":1694747,"symbol":"-[NSWindow(NSEventRouting) sendEvent:]","symbolLocation":345,"imageIndex":11},{"imageOffset":11003419,"imageIndex":6},{"imageOffset":9635318,"symbol":"-[NSApplication(NSEventRouting) sendEvent:]","symbolLocation":346,"imageIndex":11},{"imageOffset":10417330,"imageIndex":6},{"imageOffset":5181663,"symbol":"-[NSApplication _handleEvent:]","symbolLocation":65,"imageIndex":11},{"imageOffset":196127,"symbol":"-[NSApplication run]","symbolLocation":640,"imageIndex":11},{"imageOffset":10962090,"imageIndex":6},{"imageOffset":9912253,"imageIndex":6},{"imageOffset":9329454,"imageIndex":6},{"imageOffset":9143363,"imageIndex":6},{"imageOffset":10685066,"imageIndex":6},{"imageOffset":9546888,"imageIndex":6},{"imageOffset":271794,"imageIndex":6},{"imageOffset":25510,"symbol":"start","symbolLocation":1942,"imageIndex":0}]},{"id":7574398,"name":"com.apple.rosetta.exceptionserver","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":34097745362944},"r12":{"value":4351272028,"region":"<translation info unavailable>"},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":4462471132043},"tmp0":{"value":10337986281472}},"rbx":{"value":4462471132043},"r8":{"value":7939},"r15":{"value":6509563904},"r10":{"value":15586436317184},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":4496173952},"rflags":{"value":582},"rax":{"value":268451845},"rsp":{"value":10337986281472},"r11":{"value":0},"rcx":{"value":17314086914},"r14":{"value":140705800729292},"rsi":{"value":2616}},"frames":[{"imageOffset":17044,"imageIndex":4}]},{"id":7574508,"name":"com.apple.NSEventThread","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":276007483342848},"r12":{"value":4294967295},"rosetta":{"tmp2":{"value":140703374098042},"tmp1":{"value":140705795156840},"tmp0":{"value":18446744073709551615}},"rbx":{"value":276007483342848},"r8":{"value":0},"r15":{"value":276007483342848},"r10":{"value":276007483342848},"rdx":{"value":8589934592},"rdi":{"value":4294967295},"r9":{"value":276007483342848},"r13":{"value":21592279046},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":21592279046},"r14":{"value":2},"rsi":{"value":2}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":6766,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":8},{"imageOffset":65146,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":8},{"imageOffset":35730,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":8},{"imageOffset":7519,"symbol":"mach_msg","symbolLocation":19,"imageIndex":8},{"imageOffset":506697,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":143,"imageIndex":9},{"imageOffset":501180,"symbol":"__CFRunLoopRun","symbolLocation":1371,"imageIndex":9},{"imageOffset":498329,"symbol":"CFRunLoopRunSpecific","symbolLocation":557,"imageIndex":9},{"imageOffset":1686016,"symbol":"_NSEventThread","symbolLocation":122,"imageIndex":11},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574509,"name":"TSK bkgd","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13002907648},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":7912482,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574512,"name":"NFM_Region_0","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":17152},"r10":{"value":0},"rdx":{"value":17152},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":73671574045696},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":1280},"rcx":{"value":0},"r14":{"value":13003444224},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":8392771,"imageIndex":6},{"imageOffset":7912534,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574513,"name":"IOPAppMain","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13003980800},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":5235989,"imageIndex":6},{"imageOffset":7912512,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574514,"name":"ant_main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":249963000},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":787000},"r15":{"value":768},"r10":{"value":0},"rdx":{"value":768},"rdi":{"value":249963000},"r9":{"value":65704},"r13":{"value":3736144807020288},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":870144},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26524,"symbol":"_pthread_cond_wait","symbolLocation":1260,"imageIndex":12},{"imageOffset":7911168,"imageIndex":6},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":5060277,"imageIndex":6},{"imageOffset":7912512,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574515,"name":"GPS main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13005053952},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":7912482,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574516,"name":"SNS main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13005590528},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":7912482,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574517,"name":"fit activity","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":54016},"r10":{"value":0},"rdx":{"value":54016},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":232001248482304},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13006127104},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":5495138,"imageIndex":6},{"imageOffset":7912512,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574518,"name":"ftm main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":998928000},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":998928000},"r9":{"value":65704},"r13":{"value":865319946228736},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":256},"rcx":{"value":0},"r14":{"value":201728},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26524,"symbol":"_pthread_cond_wait","symbolLocation":1260,"imageIndex":12},{"imageOffset":7911168,"imageIndex":6},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":5558239,"imageIndex":6},{"imageOffset":7912512,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574519,"name":"TVM main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":998418000},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":4494803968},"r15":{"value":414720},"r10":{"value":0},"rdx":{"value":414720},"rdi":{"value":998418000},"r9":{"value":65704},"r13":{"value":1781213132379392},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":1792},"rcx":{"value":0},"r14":{"value":414976},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26524,"symbol":"_pthread_cond_wait","symbolLocation":1260,"imageIndex":12},{"imageOffset":7911168,"imageIndex":6},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":7556309,"imageIndex":6},{"imageOffset":7912512,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574520,"name":"TVM defrag","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13007736832},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":7912482,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"triggered":true,"id":7574530,"name":"parse main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13008272176},"r12":{"value":455266556360},"rosetta":{"tmp2":{"value":4839818864},"tmp1":{"value":103015},"tmp0":{"value":140705800728900}},"rbx":{"value":18446744073709551615},"r8":{"value":7574530},"r15":{"value":9223372032559808512},"r10":{"value":18446744073709551615},"rdx":{"value":13672},"rdi":{"value":0},"r9":{"value":1889785610239},"r13":{"value":4530935390162460091},"rflags":{"value":647},"rax":{"value":1054940603},"rsp":{"value":13008272128},"r11":{"value":18446744073709551615},"rcx":{"value":32},"r14":{"value":12192631728290160924},"rsi":{"value":140533225823336}},"frames":[{"imageOffset":23060,"symbol":"_platform_memmove$VARIANT$Rosetta","symbolLocation":340,"imageIndex":13},{"imageOffset":131608,"imageIndex":6},{"imageOffset":137795,"imageIndex":6},{"imageOffset":7912512,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574531,"name":"GPX archive trk","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13008809984},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":8462245,"imageIndex":6},{"imageOffset":7912512,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574532,"name":"URM Main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13009346560},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":5377317,"imageIndex":6},{"imageOffset":7912512,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574533,"name":"mma sql bkg","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13009883136},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":7912482,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574535,"name":"TLG main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":999832000},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":13010955912},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":999832000},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":512},"rsi":{"value":58373}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26524,"symbol":"_pthread_cond_wait","symbolLocation":1260,"imageIndex":12},{"imageOffset":7911168,"imageIndex":6},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":8461774,"imageIndex":6},{"imageOffset":7912534,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574536,"name":"libcurl Async H","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13011492864},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":5351349,"imageIndex":6},{"imageOffset":7912534,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574537,"name":"Download Manage","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13012029440},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7915882,"imageIndex":6},{"imageOffset":5360901,"imageIndex":6},{"imageOffset":7912534,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574538,"name":"Shell main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":4294966287},"r12":{"value":140534695639832},"rosetta":{"tmp2":{"value":140703374067796},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":140533610595840},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":4325915480},"r9":{"value":4294966287},"r13":{"value":4325915104},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":3806},"r11":{"value":4294966272},"rcx":{"value":0},"r14":{"value":4325915232},"rsi":{"value":140533610597088}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":34910,"symbol":"__accept","symbolLocation":10,"imageIndex":8},{"imageOffset":8440994,"imageIndex":6},{"imageOffset":8428199,"imageIndex":6},{"imageOffset":7912512,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574539,"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":70594,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":14},{"imageOffset":833474,"imageIndex":6},{"imageOffset":833215,"imageIndex":6},{"imageOffset":832866,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":160},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13013102592},"rsi":{"value":0}}},{"id":7574540,"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":34910,"symbol":"__accept","symbolLocation":10,"imageIndex":8},{"imageOffset":1238812,"imageIndex":6},{"imageOffset":1058540,"imageIndex":6},{"imageOffset":9989996,"imageIndex":6},{"imageOffset":9988607,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":51617},"r12":{"value":4308350848},"rosetta":{"tmp2":{"value":140703374067796},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":13013638536},"r8":{"value":13013638672},"r15":{"value":4325358328},"r10":{"value":13013638536},"rdx":{"value":0},"rdi":{"value":140534695485536},"r9":{"value":51617},"r13":{"value":13013639168},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":1},"r11":{"value":4160749568},"rcx":{"value":0},"r14":{"value":140534695485536},"rsi":{"value":140534695485472}}},{"id":7574653,"name":"Shell handler","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13014175744},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":8},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":12},{"imageOffset":7910556,"imageIndex":6},{"imageOffset":1236100,"imageIndex":6},{"imageOffset":8440346,"imageIndex":6},{"imageOffset":8437619,"imageIndex":6},{"imageOffset":8430599,"imageIndex":6},{"imageOffset":7912512,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7574655,"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":20854,"symbol":"__recvfrom","symbolLocation":10,"imageIndex":8},{"imageOffset":8441985,"imageIndex":6},{"imageOffset":8437778,"imageIndex":6},{"imageOffset":1225482,"imageIndex":6},{"imageOffset":1256543,"imageIndex":6},{"imageOffset":9989996,"imageIndex":6},{"imageOffset":9988607,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":0},"r12":{"value":12},"rosetta":{"tmp2":{"value":140703374053740},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":13014711580},"r15":{"value":140533746910384},"r10":{"value":0},"rdx":{"value":12},"rdi":{"value":140533746910432},"r9":{"value":0},"r13":{"value":13014711553},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":140533746910432},"rsi":{"value":140533746910384}}},{"id":7574700,"frames":[{"imageOffset":5876158,"imageIndex":6},{"imageOffset":5693761,"imageIndex":6},{"imageOffset":5692898,"imageIndex":6},{"imageOffset":5900598,"imageIndex":6},{"imageOffset":5914769,"imageIndex":6},{"imageOffset":5918054,"imageIndex":6},{"imageOffset":5623669,"imageIndex":6},{"imageOffset":6393886,"imageIndex":6},{"imageOffset":6391395,"imageIndex":6},{"imageOffset":6389626,"imageIndex":6},{"imageOffset":6389874,"imageIndex":6},{"imageOffset":7479419,"imageIndex":6},{"imageOffset":7452763,"imageIndex":6},{"imageOffset":7835166,"imageIndex":6},{"imageOffset":7848447,"imageIndex":6},{"imageOffset":7850267,"imageIndex":6},{"imageOffset":7853610,"imageIndex":6},{"imageOffset":7473134,"imageIndex":6},{"imageOffset":7793816,"imageIndex":6},{"imageOffset":1610525,"imageIndex":6},{"imageOffset":1354203,"imageIndex":6},{"imageOffset":1617394,"imageIndex":6},{"imageOffset":1346302,"imageIndex":6},{"imageOffset":1256543,"imageIndex":6},{"imageOffset":9989996,"imageIndex":6},{"imageOffset":9988607,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13015243472},"r12":{"value":93},"rosetta":{"tmp2":{"value":4336377684},"tmp1":{"value":4313169880},"tmp0":{"value":140900}},"rbx":{"value":7045},"r8":{"value":4294967296},"r15":{"value":1},"r10":{"value":84},"rdx":{"value":10240},"rdi":{"value":13015243512},"r9":{"value":43},"r13":{"value":98},"rflags":{"value":643},"rax":{"value":140534426206208},"rsp":{"value":13015243264},"r11":{"value":8},"rcx":{"value":35225},"r14":{"value":140534694382496},"rsi":{"value":3174834677}}},{"id":7575721,"name":"com.apple.coreanimation.render-server","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":522521426264064},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374098042},"tmp1":{"value":140705795156840},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":522521426264064},"r10":{"value":0},"rdx":{"value":8589934592},"rdi":{"value":0},"r9":{"value":522521426264064},"r13":{"value":21525170190},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":21525170190},"r14":{"value":2},"rsi":{"value":2}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":6766,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":8},{"imageOffset":65146,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":8},{"imageOffset":35730,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":8},{"imageOffset":7519,"symbol":"mach_msg","symbolLocation":19,"imageIndex":8},{"imageOffset":299344,"symbol":"CA::Render::Server::server_thread(void*)","symbolLocation":534,"imageIndex":15},{"imageOffset":298793,"symbol":"thread_fun(void*)","symbolLocation":25,"imageIndex":15},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7575729,"name":"WebCore: Scrolling","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":487096536006656},"r12":{"value":4294967295},"rosetta":{"tmp2":{"value":140703374098042},"tmp1":{"value":140705795156840},"tmp0":{"value":18446744073709551615}},"rbx":{"value":487096536006656},"r8":{"value":115801232},"r15":{"value":487096536006656},"r10":{"value":487096536006656},"rdx":{"value":8589934592},"rdi":{"value":4294967295},"r9":{"value":487096536006656},"r13":{"value":21592279046},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":115801232},"r11":{"value":0},"rcx":{"value":21592279046},"r14":{"value":2},"rsi":{"value":2}},"frames":[{"imageOffset":140705795156600,"imageIndex":7},{"imageOffset":6766,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":8},{"imageOffset":65146,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":8},{"imageOffset":35730,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":8},{"imageOffset":7519,"symbol":"mach_msg","symbolLocation":19,"imageIndex":8},{"imageOffset":506697,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":143,"imageIndex":9},{"imageOffset":501180,"symbol":"__CFRunLoopRun","symbolLocation":1371,"imageIndex":9},{"imageOffset":498329,"symbol":"CFRunLoopRunSpecific","symbolLocation":557,"imageIndex":9},{"imageOffset":1001609,"symbol":"CFRunLoopRun","symbolLocation":40,"imageIndex":9},{"imageOffset":2062450,"symbol":"WTF::Detail::CallableWrapper<WTF::RunLoop::create(char const*, WTF::ThreadType, WTF::Thread::QOS)::$_1, void>::call()","symbolLocation":82,"imageIndex":16},{"imageOffset":2172605,"symbol":"WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*)","symbolLocation":237,"imageIndex":16},{"imageOffset":11177,"symbol":"WTF::wtfThreadEntryPoint(void*)","symbolLocation":9,"imageIndex":16},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":12},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":12}]},{"id":7575807,"frames":[{"imageOffset":141644,"imageIndex":4}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13021827072},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13022363648},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":173831},"r14":{"value":0},"rsi":{"value":0}}},{"id":7576406,"frames":[{"imageOffset":141644,"imageIndex":4}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13000183808},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13000720384},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":101159},"r14":{"value":0},"rsi":{"value":0}}},{"id":7581078,"frames":[{"imageOffset":141644,"imageIndex":4}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13001281536},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13001818112},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":96691},"r14":{"value":0},"rsi":{"value":0}}}],
    "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "base" : 8624693248,
    "size" : 655360,
    "uuid" : "d5406f23-6967-39c4-beb5-6ae3293c7753",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 5077352448,
    "CFBundleShortVersionString" : "7.0",
    "CFBundleIdentifier" : "com.apple.audio.codecs.Components",
    "size" : 10043392,
    "uuid" : "026b9761-d7e5-392e-bd22-73638035931b",
    "path" : "\/System\/Library\/Components\/AudioCodecs.component\/Contents\/MacOS\/AudioCodecs",
    "name" : "AudioCodecs",
    "CFBundleVersion" : "7.0"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4797374464,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.apple.AppleMetalOpenGLRenderer",
    "size" : 458752,
    "uuid" : "e8731326-3e64-3623-8b4f-7b010926a559",
    "path" : "\/System\/Library\/Extensions\/AppleMetalOpenGLRenderer.bundle\/Contents\/MacOS\/AppleMetalOpenGLRenderer",
    "name" : "AppleMetalOpenGLRenderer",
    "CFBundleVersion" : "1"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4492300288,
    "size" : 65536,
    "uuid" : "7e101877-a6ff-3331-99a3-4222cb254447",
    "path" : "\/usr\/lib\/libobjc-trampolines.dylib",
    "name" : "libobjc-trampolines.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 140703124201472,
    "size" : 196608,
    "uuid" : "2c5acb8c-fbaf-31ab-aeb3-90905c3fa905",
    "path" : "\/usr\/libexec\/rosetta\/runtime",
    "name" : "runtime"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4484796416,
    "size" : 344064,
    "uuid" : "a61ec9e9-1174-3dc6-9cdb-0d31811f4850",
    "path" : "\/Library\/Apple\/*\/libRosettaRuntime",
    "name" : "libRosettaRuntime"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4307292160,
    "CFBundleShortVersionString" : "6.4.0",
    "CFBundleIdentifier" : "com.garmin.connectiq.simulator",
    "size" : 16564224,
    "uuid" : "85059f24-2407-3ef8-b459-b1bc3ac1586d",
    "path" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
    "name" : "simulator",
    "CFBundleVersion" : "6.4.0"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703374032896,
    "size" : 241656,
    "uuid" : "4df0d732-7fc4-3200-8176-f1804c63f2c8",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703374688256,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 4820989,
    "uuid" : "4d842118-bb65-3f01-9087-ff1a2e3ab0d5",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "2106"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703556816896,
    "CFBundleShortVersionString" : "2.1.1",
    "CFBundleIdentifier" : "com.apple.HIToolbox",
    "size" : 2736117,
    "uuid" : "06bf0872-3b34-3c7b-ad5b-7a447d793405",
    "path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
    "name" : "HIToolbox"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703430971392,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 20996092,
    "uuid" : "27fed5dd-d148-3238-bc95-1dac5dd57fa1",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2487.20.107"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703374274560,
    "size" : 49152,
    "uuid" : "c64722b0-e96a-3fa5-96c3-b4beaf0c494a",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703374471168,
    "size" : 40960,
    "uuid" : "c94f952c-2787-30d2-ab77-ee474abd88d6",
    "path" : "\/usr\/lib\/system\/libsystem_platform.dylib",
    "name" : "libsystem_platform.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703373410304,
    "size" : 520192,
    "uuid" : "b0f79a73-e705-38c8-a162-2465ed2adfaa",
    "path" : "\/usr\/lib\/libc++.1.dylib",
    "name" : "libc++.1.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703519268864,
    "CFBundleShortVersionString" : "1.11",
    "CFBundleIdentifier" : "com.apple.QuartzCore",
    "size" : 3833850,
    "uuid" : "a1fb38a4-9d16-3fa7-ac42-be6f87a69a7a",
    "path" : "\/System\/Library\/Frameworks\/QuartzCore.framework\/Versions\/A\/QuartzCore",
    "name" : "QuartzCore",
    "CFBundleVersion" : "1109.3"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703861231616,
    "CFBundleShortVersionString" : "19616",
    "CFBundleIdentifier" : "com.apple.JavaScriptCore",
    "size" : 29245419,
    "uuid" : "c925d606-3694-3941-8463-00a074e9d65b",
    "path" : "\/System\/Library\/Frameworks\/JavaScriptCore.framework\/Versions\/A\/JavaScriptCore",
    "name" : "JavaScriptCore",
    "CFBundleVersion" : "19616.2.9.11.12"
    "sharedCache" : {
    "base" : 140703369871360,
    "size" : 21474836480,
    "uuid" : "926a5dba-1202-3711-9462-94bb6fd43274"
    "vmSummary" : "ReadOnly portion of Libraries: Total=988.0M resident=0K(0%) swapped_out_or_unallocated=988.0M(100%)\nWritable regions: Total=6.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=6.1G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 256K 2 \nActivity Tracing 256K 1 \nCG image 1720K 45 \nCG raster data 1976K 4 \nColorSync 264K 34 \nCoreAnimation 5240K 151 \nCoreGraphics 16K 3 \nCoreImage 16K 1 \nCoreUI image data 3444K 26 \nDispatch continuations 96.0M 1 \nFoundation 16K 1 \nKernel Alloc Once 8K 1 \nMALLOC 1.7G 94 \nMALLOC guard page 384K 24 \nRosetta Arena 4096K 2 \nRosetta Generic 1936K 481 \nRosetta IndirectBranch 2048K 1 \nRosetta JIT 128.0M 1 \nRosetta Return Stack 600K 60 \nRosetta Thread Context 600K 60 \nSTACK GUARD 12K 3 \nStack 23.3M 33 \nStack Guard 56.1M 27 \nVM_ALLOCATE 134.6M 32 \nVM_ALLOCATE (reserved) 3.9G 3 reserved VM address space (unallocated)\nWebKit Malloc 192.0M 6 \n__CTF 824 1 \n__DATA 42.0M 666 \n__DATA_CONST 46.4M 447 \n__DATA_DIRTY 1795K 238 \n__FONT_DATA 2352 1 \n__GLSLBUILTINS 5174K 1 \n__LINKEDIT 181.2M 12 \n__OBJC_RO 70.7M 1 \n__OBJC_RW 2154K 2 \n__TEXT 806.9M 683 \ndyld private memory 260K 2 \nmapped file 6.9G 1069 \nshared memory 812K 16 \nunshared pmap 12.3M 9 \n=========== ======= ======= \nTOTAL 14.2G 4245 \nTOTAL, minus reserved VM space 10.3G 4245 \n",
    "legacyInfo" : {
    "threadTriggered" : {
    "name" : "parse main"
    "logWritingSignature" : "4119b717c38d15a3788d7fffcbf203f111e2e49c",
    "trialInfo" : {
    "rollouts" : [
    "rolloutId" : "64b21a7351cbb02ce3442e4e",
    "factorPackIds" : {
    "REMINDERS_GROCERY" : "65542c604a6560536bdb1d22"
    "deploymentId" : 240000032
    "rolloutId" : "63f9578e238e7b23a1f3030a",
    "factorPackIds" : {
    "deploymentId" : 240000005
    "experiments" : [
    "reportNotes" : [
    "PC register does not match crashing frame (0x0 vs 0x7FF80EA7CA14)"
Comment
    Translated Report (Full Report Below)
    Process: simulator [10030]
    Path: /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
    Identifier: com.garmin.connectiq.simulator
    Version: 6.4.0 (6.4.0)
    Code Type: X86-64 (Translated)
    Parent Process: launchd [1]
    User ID: 501
    Date/Time: 2023-12-18 08:00:13.0421 -0800
    OS Version: macOS 14.1.2 (23B92)
    Report Version: 12
    Anonymous UUID: 5A18F4F2-35C0-936C-34A5-D2F176301C89
    Sleep/Wake UUID: D0E52FB6-08F0-434D-8283-D55F2E0AF9AE
    Time Awake Since Boot: 760000 seconds
    Time Since Wake: 9231 seconds
    System Integrity Protection: enabled
    Notes:
    Crashed Thread: 13 parse main
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
    Exception Codes: 0x0000000000000001, 0x0000000000000000
    Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
    Terminating Process: exc handler [10030]
    VM Region Info: 0 is not in any region. Bytes before following region: 4307292160
    REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
    __TEXT 100bc1000-101b8d000 [ 15.8M] r-x/r-x SM=COW ...cOS/simulator
    Error Formulating Crash Report:
    Thread 0:: Dispatch queue: com.apple.main-thread
    0 ??? 0x7ff89ef02a78 ???
    1 libsystem_kernel.dylib 0x7ff80ea0db0a _kernelrpc_mach_port_type_trap + 10
    2 libsystem_kernel.dylib 0x7ff80ea0fd3e mach_port_type + 24
    3 CoreFoundation 0x7ff80eb002a0 CFRunLoopAddSource + 167
    4 HIToolbox 0x7ff819861c83 _HLTBAddEventSourceToMode + 59
    5 AppKit 0x7ff812097699 _DPSNextEvent + 388
    6 AppKit 0x7ff81298b348 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1304
    7 AppKit 0x7ff8122828a0 -[NSWindow(NSEventRouting) trackEventsMatchingMask:timeout:mode:handler:] + 261
    8 AppKit 0x7ff8122817b1 -[NSDragEventTracker trackEvent:usingHandler:] + 889
    9 AppKit 0x7ff812280d12 NSControlTrackMouse + 1459
    10 AppKit 0x7ff81228073b -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 125
    11 AppKit 0x7ff8123edfd0 -[NSSliderCell trackMouse:inRect:ofView:untilMouseUp:] + 119
    12 AppKit 0x7ff81227f9f8 -[NSControl mouseDown:] + 666
    13 simulator 0x10165160e 0x100bc1000 + 11077134
    14 simulator 0x101643a12 0x100bc1000 + 11020818
    15 AppKit 0x7ff81227e39d -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 4580
    16 AppKit 0x7ff8121f6fca -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 404
    17 AppKit 0x7ff8121f6c1b -[NSWindow(NSEventRouting) sendEvent:] + 345
    18 simulator 0x10163f61b 0x100bc1000 + 11003419
    19 AppKit 0x7ff8129895f6 -[NSApplication(NSEventRouting) sendEvent:] + 346
    20 simulator 0x1015b04b2 0x100bc1000 + 10417330
    21 AppKit 0x7ff81254a0df -[NSApplication _handleEvent:] + 65
    22 AppKit 0x7ff812088e1f -[NSApplication run] + 640
    23 simulator 0x1016354aa 0x100bc1000 + 10962090
    24 simulator 0x101534fbd 0x100bc1000 + 9912253
    25 simulator 0x1014a6b2e 0x100bc1000 + 9329454
    26 simulator 0x101479443 0x100bc1000 + 9143363
    27 simulator 0x1015f1a8a 0x100bc1000 + 10685066
    28 simulator 0x1014dbc88 0x100bc1000 + 9546888
    29 simulator 0x100c035b2 0x100bc1000 + 271794
    30 dyld 0x20212c3a6 start + 1942
    Thread 1:: com.apple.rosetta.exceptionserver
    0 runtime 0x7ff7ffbce294 0x7ff7ffbca000 + 17044
    Thread 2:: com.apple.NSEventThread
    1 libsystem_kernel.dylib 0x7ff80ea0da6e mach_msg2_trap + 10
    2 libsystem_kernel.dylib 0x7ff80ea1be7a mach_msg2_internal + 84
    3 libsystem_kernel.dylib 0x7ff80ea14b92 mach_msg_overwrite + 653
    4 libsystem_kernel.dylib 0x7ff80ea0dd5f mach_msg + 19
    5 CoreFoundation 0x7ff80eb27b49 __CFRunLoopServiceMachPort + 143
    6 CoreFoundation 0x7ff80eb265bc __CFRunLoopRun + 1371
    7 CoreFoundation 0x7ff80eb25a99 CFRunLoopRunSpecific + 557
    8 AppKit 0x7ff8121f4a00 _NSEventThread + 122
    9 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    10 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 3:: TSK bkgd
    1 libsystem_kernel.dylib 0x7ff80ea1060e __psynch_cvwait + 10
    2 libsystem_pthread.dylib 0x7ff80ea4d76b _pthread_cond_wait + 1211
    3 simulator 0x10134d96a 0x100bc1000 + 7915882
    4 simulator 0x10134cc22 0x100bc1000 + 7912482
    5 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    6 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 4:: NFM_Region_0
    4 simulator 0x1013c2043 0x100bc1000 + 8392771
    5 simulator 0x10134cc56 0x100bc1000 + 7912534
    Thread 5:: IOPAppMain
    4 simulator 0x1010bf515 0x100bc1000 + 5235989
    5 simulator 0x10134cc40 0x100bc1000 + 7912512
    Thread 6:: ant_main
    2 libsystem_pthread.dylib 0x7ff80ea4d79c _pthread_cond_wait + 1260
    3 simulator 0x10134c700 0x100bc1000 + 7911168
    4 simulator 0x10134d96a 0x100bc1000 + 7915882
    5 simulator 0x1010946b5 0x100bc1000 + 5060277
    6 simulator 0x10134cc40 0x100bc1000 + 7912512
    7 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    8 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 7:: GPS main
    Thread 8:: SNS main
    Thread 9:: fit activity
    4 simulator 0x1010fe962 0x100bc1000 + 5495138
    Thread 10:: ftm main
    5 simulator 0x10110dfdf 0x100bc1000 + 5558239
    Thread 11:: TVM main
    5 simulator 0x1012f5cd5 0x100bc1000 + 7556309
    Thread 12:: TVM defrag
    Thread 13 Crashed:: parse main
    0 libsystem_platform.dylib 0x7ff80ea7ca14 _platform_memmove$VARIANT$Rosetta + 340
    1 simulator 0x100be1218 0x100bc1000 + 131608
    2 simulator 0x100be2a43 0x100bc1000 + 137795
    3 simulator 0x10134cc40 0x100bc1000 + 7912512
    4 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    5 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 14:: GPX archive trk
    4 simulator 0x1013d2fa5 0x100bc1000 + 8462245
    Thread 15:: URM Main
    4 simulator 0x1010e1d25 0x100bc1000 + 5377317
    Thread 16:: mma sql bkg
    Thread 17:: TLG main
    5 simulator 0x1013d2dce 0x100bc1000 + 8461774
    6 simulator 0x10134cc56 0x100bc1000 + 7912534
    Thread 18:: libcurl Async H
    4 simulator 0x1010db7b5 0x100bc1000 + 5351349
    Thread 19:: Download Manage
    4 simulator 0x1010ddd05 0x100bc1000 + 5360901
    Thread 20:: Shell main
    1 libsystem_kernel.dylib 0x7ff80ea1485e __accept + 10
    2 simulator 0x1013cdca2 0x100bc1000 + 8440994
    3 simulator 0x1013caaa7 0x100bc1000 + 8428199
    4 simulator 0x10134cc40 0x100bc1000 + 7912512
    Thread 21:
    3 libc++.1.dylib 0x7ff80e9853c2 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18
    4 simulator 0x100c8c7c2 0x100bc1000 + 833474
    5 simulator 0x100c8c6bf 0x100bc1000 + 833215
    6 simulator 0x100c8c562 0x100bc1000 + 832866
    Thread 22:
    2 simulator 0x100cef71c 0x100bc1000 + 1238812
    3 simulator 0x100cc36ec 0x100bc1000 + 1058540
    Thread 23:: Shell handler
    3 simulator 0x10134c49c 0x100bc1000 + 7910556
    4 simulator 0x100ceec84 0x100bc1000 + 1236100
    5 simulator 0x1013cda1a 0x100bc1000 + 8440346
    6 simulator 0x1013ccf73 0x100bc1000 + 8437619
    7 simulator 0x1013cb407 0x100bc1000 + 8430599
    8 simulator 0x10134cc40 0x100bc1000 + 7912512
    Thread 24:
    1 libsystem_kernel.dylib 0x7ff80ea11176 __recvfrom + 10
    2 simulator 0x1013ce081 0x100bc1000 + 8441985
    3 simulator 0x1013cd012 0x100bc1000 + 8437778
    4 simulator 0x100cec30a 0x100bc1000 + 1225482
    5 simulator 0x100cf3c5f 0x100bc1000 + 1256543
    6 simulator 0x101547f6c 0x100bc1000 + 9989996
    7 simulator 0x1015479ff 0x100bc1000 + 9988607
    8 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    9 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 25:
    0 simulator 0x10115b9be 0x100bc1000 + 5876158
    1 simulator 0x10112f141 0x100bc1000 + 5693761
    2 simulator 0x10112ede2 0x100bc1000 + 5692898
    3 simulator 0x101161936 0x100bc1000 + 5900598
    4 simulator 0x101165091 0x100bc1000 + 5914769
    5 simulator 0x101165d66 0x100bc1000 + 5918054
    6 simulator 0x10111df75 0x100bc1000 + 5623669
    7 simulator 0x1011da01e 0x100bc1000 + 6393886
    8 simulator 0x1011d9663 0x100bc1000 + 6391395
    9 simulator 0x1011d8f7a 0x100bc1000 + 6389626
    10 simulator 0x1011d9072 0x100bc1000 + 6389874
    11 simulator 0x1012e307b 0x100bc1000 + 7479419
    12 simulator 0x1012dc85b 0x100bc1000 + 7452763
    13 simulator 0x101339e1e 0x100bc1000 + 7835166
    14 simulator 0x10133d1ff 0x100bc1000 + 7848447
    15 simulator 0x10133d91b 0x100bc1000 + 7850267
    16 simulator 0x10133e62a 0x100bc1000 + 7853610
    17 simulator 0x1012e17ee 0x100bc1000 + 7473134
    18 simulator 0x10132fc98 0x100bc1000 + 7793816
    19 simulator 0x100d4a31d 0x100bc1000 + 1610525
    20 simulator 0x100d0b9db 0x100bc1000 + 1354203
    21 simulator 0x100d4bdf2 0x100bc1000 + 1617394
    22 simulator 0x100d09afe 0x100bc1000 + 1346302
    23 simulator 0x100cf3c5f 0x100bc1000 + 1256543
    24 simulator 0x101547f6c 0x100bc1000 + 9989996
    25 simulator 0x1015479ff 0x100bc1000 + 9988607
    26 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    27 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 26:: com.apple.coreanimation.render-server
    5 QuartzCore 0x7ff8174d7150 CA::Render::Server::server_thread(void*) + 534
    6 QuartzCore 0x7ff8174d6f29 thread_fun(void*) + 25
    Thread 27:: WebCore: Scrolling
    8 CoreFoundation 0x7ff80eba0889 CFRunLoopRun + 40
    9 JavaScriptCore 0x7ff82bca4872 WTF::Detail::CallableWrapper<WTF::RunLoop::create(char const*, WTF::ThreadType, WTF::Thread::QOS)::$_1, void>::call() + 82
    10 JavaScriptCore 0x7ff82bcbf6bd WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*) + 237
    11 JavaScriptCore 0x7ff82baafba9 WTF::wtfThreadEntryPoint(void*) + 9
    12 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
    13 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
    Thread 28:
    0 runtime 0x7ff7ffbec94c 0x7ff7ffbca000 + 141644
    Thread 29:
    Thread 30:
    Thread 13 crashed with X86 Thread State (64-bit):
    rax: 0x000000003ee11dbb rbx: 0xffffffffffffffff rcx: 0x0000000000000020 rdx: 0x0000000000003568
    rdi: 0x0000000000000000 rsi: 0x00007fd071011c68 rbp: 0x00000003075a7b30 rsp: 0x00000003075a7b00
    r8: 0x0000000000739402 r9: 0x000001b7ffffffff r10: 0xffffffffffffffff r11: 0xffffffffffffffff
    r12: 0x0000006a000059c8 r13: 0x3ee11dbb3ee11dbb r14: 0xa934edf521e4611c r15: 0x7fffffff00000000
    rip: <unavailable> rfl: 0x0000000000000287
    tmp0: 0x00007ff89f453144 tmp1: 0x0000000000019267 tmp2: 0x000000012079c670
    Binary Images:
    0x202126000 - 0x2021c5fff dyld (*) <d5406f23-6967-39c4-beb5-6ae3293c7753> /usr/lib/dyld
    0x12ea24000 - 0x12f3b7fff com.apple.audio.codecs.Components (7.0) <026b9761-d7e5-392e-bd22-73638035931b> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
    0x11df22000 - 0x11df91fff com.apple.AppleMetalOpenGLRenderer (1.0) <e8731326-3e64-3623-8b4f-7b010926a559> /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer
    0x10bc31000 - 0x10bc40fff libobjc-trampolines.dylib (*) <7e101877-a6ff-3331-99a3-4222cb254447> /usr/lib/libobjc-trampolines.dylib
    0x7ff7ffbca000 - 0x7ff7ffbf9fff runtime (*) <2c5acb8c-fbaf-31ab-aeb3-90905c3fa905> /usr/libexec/rosetta/runtime
    0x10b509000 - 0x10b55cfff libRosettaRuntime (*) <a61ec9e9-1174-3dc6-9cdb-0d31811f4850> /Library/Apple/*/libRosettaRuntime
    0x100bc1000 - 0x101b8cfff com.garmin.connectiq.simulator (6.4.0) <85059f24-2407-3ef8-b459-b1bc3ac1586d> /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
    0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
    0x7ff80ea0c000 - 0x7ff80ea46ff7 libsystem_kernel.dylib (*) <4df0d732-7fc4-3200-8176-f1804c63f2c8> /usr/lib/system/libsystem_kernel.dylib
    0x7ff80eaac000 - 0x7ff80ef44ffc com.apple.CoreFoundation (6.9) <4d842118-bb65-3f01-9087-ff1a2e3ab0d5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7ff81985d000 - 0x7ff819af8ff4 com.apple.HIToolbox (2.1.1) <06bf0872-3b34-3c7b-ad5b-7a447d793405> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7ff812059000 - 0x7ff81345effb com.apple.AppKit (6.9) <27fed5dd-d148-3238-bc95-1dac5dd57fa1> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7ff80ea47000 - 0x7ff80ea52fff libsystem_pthread.dylib (*) <c64722b0-e96a-3fa5-96c3-b4beaf0c494a> /usr/lib/system/libsystem_pthread.dylib
    0x7ff80ea77000 - 0x7ff80ea80fff libsystem_platform.dylib (*) <c94f952c-2787-30d2-ab77-ee474abd88d6> /usr/lib/system/libsystem_platform.dylib
    0x7ff80e974000 - 0x7ff80e9f2fff libc++.1.dylib (*) <b0f79a73-e705-38c8-a162-2465ed2adfaa> /usr/lib/libc++.1.dylib
    0x7ff81748e000 - 0x7ff817835ff9 com.apple.QuartzCore (1.11) <a1fb38a4-9d16-3fa7-ac42-be6f87a69a7a> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7ff82baad000 - 0x7ff82d690fea com.apple.JavaScriptCore (19616) <c925d606-3694-3941-8463-00a074e9d65b> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    External Modification Summary:
    Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    VM Region Summary:
    VIRTUAL REGION
    CG image 1720K 45
    ColorSync 264K 34
    CoreGraphics 16K 3
    CoreImage 16K 1
    Foundation 16K 1
    MALLOC 1.7G 94
    STACK GUARD 12K 3
    Stack 23.3M 33
    __CTF 824 1
    __DATA 42.0M 666
    __FONT_DATA 2352 1
    __OBJC_RO 70.7M 1
    __OBJC_RW 2154K 2
    __TEXT 806.9M 683
    TOTAL 14.2G 4245
    Full Report
    "uptime" : 760000,
    "version" : 2,
    "userID" : 501,
    "osVersion" : {
    "build" : "23B92",
    "pid" : 10030,
    "bug_type" : "309",
    "parentPid" : 1,
    "wakeTime" : 9231,
    "sip" : "enabled",
    "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "size" : 655360,
    "name" : "dyld"
    "source" : "P",
    "arch" : "x86_64",
    "size" : 10043392,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 458752,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 65536,
    "source" : "P",
    "arch" : "arm64",
    "size" : 196608,
    "name" : "runtime"
    "source" : "P",
    "arch" : "arm64",
    "size" : 344064,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 16564224,
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 241656,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 4820989,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 2736117,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 20996092,
    "name" : "AppKit",
    "source" : "P",
    "arch" : "x86_64",
    "size" : 49152,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 40960,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 520192,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 3833850,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 29245419,
    "sharedCache" : {
    "legacyInfo" : {
    "trialInfo" : {
    "rollouts" : [
    "factorPackIds" : {
    "factorPackIds" : {
    "experiments" : [
    "reportNotes" : [
Children
No Data
