With no screen writes, and 3x reads of properties defined as settings; on-device and in-simulator the VM reports :
onPowerBudgetExceeded() gets triggered on all Devices and in-simulator (so at least it is consistent :) )
As these Settings Properties are stored in-memory it is unlikely Properties.getValue() can take 1,700,000uSec (1.7 seconds).
Even if that were possible, it should be reflected in Execution Time -- not Graphics Time.
Link to the Watchface working source code demonstrating this bug: https://github.com/blueacorn/Infocal/tree/2025.8.20 [note issue is fixed in mainline - reproducible on tag 2025.8.20]
Notes:
1. Properties are all defined in <setting propertyKey="@Properties... , Settings are stored in-memory at runtime, so getValue() should not cost 1,700,000 uSecs.
2. If Properties.getValue() cannot be called in partial updates, at least make it a compiler warning,
3. The side-effect on Graphics Time is very misleading - at least move the time cost to Execution Time -- not Graphics Time.
For context, the original root-cause discussion thread: https://forums.garmin.com/developer/connect-iq/f/discussion/420832/watchface-onpartialupdate-powerbudgetexceeded---with-no-screen-updates/
J__J
in reply to flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
J__J
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
