Acknowledged
CIQQA-3255
bug: vivoactive3 returns true for ActivityMonitor.Info has :pushes
I have the following code in one of my menus:
        if (ActivityMonitor.Info has :pushes) {
            addItem(settings, Rez.Strings.activityTypeWheelchairPushWalk, 65000);
            addItem(settings, Rez.Strings.activityTypeIndoorWheelchairPushWalk, 65086);
And I got an Invalid Value exception in ERA:
Error Name: Invalid Value
Occurrences: 1
First Occurrence: 2025-05-26
Last Occurrence: 2025-05-26
Devices:
vívoactive® 3: 8.20
App Versions: 0.9.6
Languages: ces
Backtrace:
SessionDebug.createSession:5
SessionDebug.session65086:73
SessionDebug.createSessionDebug:94
HikerAppView.createSession:66
SettingsMenu2.onSelect:220
However this can only happen if ActivityMonitor.Info has :pushes is true for vivoactive3.
In the simulator (SDK 8.1.1) I can't reproduce the problem neither with nor without --disable-api-has-check-removal
I am not 100% but 99% sure that in this build I used --disable-api-has-check-removal so if I understand correctly then this is a bug in the vivoactive firmware. Or in the simulator, that returns false, but then why does va3 throw the Invalid Value exception when calling:
ActivityRecording.createSession({:name => "name", :sport => 65 as Activity.Sport, :subSport => 86 as Activity.SubSport});
(which BTW doesn't fail in the simulator)
Parents
  • > Lovely, the best thing is to name similarily...
    Yeah Garmin is great at either:
    - using the same name for 2 different concepts: e.g. CIQ "app" (the general term which includes watch faces, data fields, etc.) versus "app" (as in "device app" / "watch app")
    - using different names for the same concept: e.g. "SatIQ" in marketing materials/device manual vs "Auto Select" in UI
    To be fair, in this case it's actually the same concept: an invalid value was supplied as an argument to an API function. It's just that one of them is an uncatchable error and one is an exception.
Comment
Children
No Data
