Acknowledged
Bug?: ViewLoop is not the current active page
Hi,
I have a reproducible issue with the ViewLoop on my Epix Gen 2 47mm. The issue occurs only when I open my app via its glance, and then leave it open without user interaction until the timeout sends the watch back to the watch face. If after that I open the app again, I cannot change views anymore, instead in the ViewLoop.changeView method the following exception is thrown:
Exception: ViewLoop is not the current active page
Stack:
  - pc: 0x100026b9
    File: 'D:\Projects\EVCC Garmin\evcc\source\EvccViewLoopDelegate.mc'
    Line: 21
    Function: onNextView
  - pc: 0x3000364017.5.2024 20:18:26: ViewLoop is not the current active page
Also a short press on the back button to end the app does not work anymore, but I can still switch apps by long press on the back button, or long press the light button to open the controls dialogue.
I am on latest SDK 7.1.1, Firmware-Version: 16.22, ConnectIQ-Version: 5.0.0.
The issue really only occurs when I let the app open and run into the timeout. If I open the app via the list of app instead of the glances, then there is no timeout, and the issue does not occur, even if I leave the app open for a few minutes and then leave it via the back button.
Here is my onNextView implementation of the ViewLoop delegate, where the exception from changeView is caught:
function onNextView() {
    try {
        return _viewLoop.changeView( WatchUi.ViewLoop.DIRECTION_NEXT );
    } catch ( ex ) {
        EvccHelper.debugException( ex );
        return false;
  • I now created a modified version of the Primates sample app, with an added glance. I can reproduce the issue with this modified version.
    7367.Primates.zip
    Here a video of reproducing the issue with the Primates app. First, starting the app and showing how it works normally.
    And second, then starting it again after the timeout:
  • I found some details and for me everything points out to a bug in Garmin's code.
    Basically under the error condition (after the timeout) my onUpdate function is called again and again, and the current view is not set, WatchUi.getCurrentView returns null, which leads to the exception described above.
    Would be great if someone from the Garmin team could help with this.
    Here some details on my latest findings:
    https://forums.garmin.com/developer/connect-iq/f/discussion/372049/exception-viewloop-is-not-the-current-active-page/1778327#1778327
