Both in SDK 6.4.2 and 7.1.0 the following tests should fail (throw an AssertException) but they PASS:
(:test)
function barAssertTest(logger as Logger) as Boolean {
var expected = "FOO";
var actual = "BAR";
Test.assert(expected.equals(actual));
return true;
(:test)
function barEqualTest(logger as Logger) as Boolean {
var actual = "BAR";
Test.assertEqual(expected, actual);
return true;
(:test)
function barEqualMessageTest(logger as Logger) as Boolean {
var actual = "BAR";
Test.assertEqualMessage(expected, actual, "expected: " + expected + ", actual: " + actual + ".");
return true;
I run the tests from VSC on fr955 using the following configuration in launch.json:
"type": "monkeyc",
"request": "launch",
"name": "Run Tests",
"runTests": true,
"device": "${command:GetTargetDevice}"
NOTE: I haven't tested other functions or other devices, so probably there are other related bugs as well.
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
