Reproducible scenario (Visual Studio Code, Windows 11):
- Create a Monkey C Barrel project in "C:\Folder name with spaces\MyBarrel"
- Create a Monkey C App, e.g. a Simple Data Field
- In this app, configure a monkey barrel: Configure Monkey Barrel > Add Monkey Barrel > Add a barrel project > C:\Folder name with spaces\MyBarrel\monkey.jungle
- The contents of the app's barrels.jungle file looks like this:
MyBarrel = [c:\Folder name with spaces\MyBarrel\monkey.jungle] base.barrelPath = $(base.barrelPath);$(MyBarrel)
Note that there are no quotes around the path to the monkey.jungle file.
- In a source file of the Simple Data Field app created in step 2, add the import statement to MyBarrel, i.e.: import MyBarrel;
- A wiggly line under this import statement appears, and if you hover over it, the error message shows: Cannot find module '$.MyBarrel' in import statement
To solve this error by hand, you have to put quotes around the path in the barrels.jungle file:
MyBarrel = ["c:\Folder name with spaces\MyBarrel\monkey.jungle"]
This is a small bug, and there is an easy workaround, but it would still be nice if it could be solved.
flocsy🤠
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
flocsy🤠
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
