Acknowledged
CIQQA-3776
[bug] Simulator bug for older systems
My layout is messed up when I use drawRadialText on I guess devices with system 7, to make it easy I'll talk about system 7 where it fails.
However, if I first choose to run it on a system 8 device and re-use the simulator screen to run it on a system 7 device it works ok.
This is a typical line of code where it happens:
dc.drawRadialText(width/2, height/2, vectorBdf, strBottomDataTXT, 0, angleBottomDataTXT, r, Graphics.RADIAL_TEXT_DIRECTION_CLOCKWISE); // Graphics.TEXT_JUSTIFY_RIGHT replaced with 0
The textstring is composed from two sets of Complication.shortLabel and Complication.value values, that have some simple preformatting to reduce the errors in the complication object on beforehand with a calculated maximum range for the total length of the string.
On the left before running a system 8 device on beforehand, on the right after doing so:
I could test the outcome on Venu 3 and Fenix 8, on both it works perfectly, but they both also work perfectly in the simulator. In the simulator for example the Approach S70 and fenix 7 series have this problem.
Parents
  • > Sometimes (too many) the simulator remembers things it shouldn't. I totally agree it's an annoying bug that Garmin should fix
    But in this case, I think beva is saying that the sim bug in the older (System 7) device is only "fixed" (worked around) if he runs a newer device (System 8) first.
    So the primary complaint isn't that the sim is remembering something it shouldn't. The primary complaint is that the sim has a bug in the first place (drawRadialText doesn't work properly on System 7 devices), but the observation is that running the same code on a newer device (System 8) beforehand will work around the problem.
    In other words, if Garmin were to fix the problem where the sim inappropriately remembers the behaviour of a previously-simulated System 8 device when simulating a System 7 device, that still wouldn't fix the root problem that's being reported.
Comment
Children
No Data
