With previous versions, it was possible to have static dictionaries inside classes. With SDK version 4.1.6, it is not working anymore.
Previously working:
class Test {
static private var some_variable = {};
static function test(some_arg){
return;
static function other(some_arg){
return some_variable.get(some_arg);
Now with 4.1.6, the debugger throws a runtime 'some_variable not found' error as soon the static function test is called.
- tested with different variable types, only Lang.Dictionary causes the above error.
- the static dictionary needs to be accessed in some other static function, so removing the static qualifier is not an option.
dbrobert
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
dbrobert
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
