Acknowledged
Bug report: ANT GenericChannel.release causes issues with other channels
In our app we have 3 ANT generic channels.  One is a master, two are slaves.
I am trying to change one of the channels to a BackgroundScan channel.
To do that I have to firstly switch it to a "Ant.CHANNEL_TYPE_RX_ONLY" type.  To do that I have to reinitialise the channel, i.e.:
channel = new Ant.ChannelAssignment
                Ant.CHANNEL_TYPE_RX_ONLY,
                Ant.NETWORK_PUBLIC
I believe we cannot change it on the fly.  Since this channel is already assigned I have to release it first, using GenericChannel.release().
When changing back to standard master channel, we do GenericChannel.close() then GenericChannel.release().  On this GenericChannel.release() command the first channel I assigned stops working - I have isolated this line as being the problem. The first channel is still transmitting data but the onMessage event stops getting called.
So in short "releasing" an rx only background scanning channel causes the first assigned channel in my app to stop working.
Any ideas of a workaround?
Parents
  • Hi Brandon,
    Ok, I have the issue working in a demo app. Here is what happens:
    - I open 3 speed sensor channels and 1 power meter channel.  I am using SimulANT to create multiple speed and power meters to listen to.
    - I can toggle the power meter from standard mode to scan mode.  When I hit the "GenericChannel.release();" line the first time (on "switchToScan") the first speed  sensor channel closes.  When I switch back from scan ("switchBackFromScan") again the "GenericChannel.release()" line causes the second speed sensor channel to close.
    Here are the speed and power sensor channel codes.  Let me know if you want the full app.
    using Toybox.Ant as Ant;
    using Toybox.System as Sys;
    class SpdSensor extends Ant.GenericChannel
    	const DEVICE_TYPE = 123;
    	const PERIOD = 8118;
    	const DEVICE_NUMBER = 0;
    	var device_cfg;
    	var msgCount = 0;
    	hidden var m_channel;
    	function initialize()
    		m_channel = new Ant.ChannelAssignment
    			Ant.CHANNEL_TYPE_RX_NOT_TX,
    			Ant.NETWORK_PLUS
    		GenericChannel.initialize(method(:onMessage), m_channel);
    		device_cfg = new Ant.DeviceConfig
    			:deviceNumber => DEVICE_NUMBER,
    			:deviceType => DEVICE_TYPE,
    			:messagePeriod => PERIOD,
    			:transmissionType =>0,
    			:radioFrequency => 57,
    			:searchTimeoutLowPriority => 10,
    			:searchThreshold => 0
    		GenericChannel.setDeviceConfig(device_cfg);
    		GenericChannel.open();
    	function close()
    		GenericChannel.close();
    	function onMessage(msg)
    		var payload = msg.getPayload();
    		if (Ant.MSG_ID_BROADCAST_DATA == msg.messageId)
    			msgCount++;
    class PwrSensor extends Ant.GenericChannel
    	const DEVICE_TYPE = 11;
    	const PERIOD = 8182;
    	var device_cfg;
    	var msgCount = 0;
    	hidden var m_scanning = false;
    			Ant.NETWORK_PLUS
    	function close()
    	function switchToScan()
    			Ant.NETWORK_PLUS
    		m_channel.setBackgroundScan(true);
    			:deviceNumber => 0,
    	function getText()
    		if (m_scanning)
    			return "Click Menu to stop pwr scan";
    		else
    			return "Click Menu to switch pwr to scan";
    	function toggleScan()
    		if (m_scanning)
    			switchBackFromScan();
    			m_scanning = false;
    		else
    			switchToScan();
    			m_scanning = true;
    	function switchBackFromScan()
    			Ant.NETWORK_PLUS
    		m_channel.setBackgroundScan(false);
    			:deviceNumber => 0,
    			msgCount++;
Comment
  • Hi Brandon,
    	var device_cfg;
    	var msgCount = 0;
    			Ant.NETWORK_PLUS
    	function close()
    			msgCount++;
    	var device_cfg;
    	var msgCount = 0;
    			Ant.NETWORK_PLUS
    	function close()
    			Ant.NETWORK_PLUS
    			:deviceNumber => 0,
    	function getText()
    		if (m_scanning)
    		else
    		if (m_scanning)
    			m_scanning = false;
    		else
    			switchToScan();
    			m_scanning = true;
    			Ant.NETWORK_PLUS
    			:deviceNumber => 0,
    			msgCount++;
Children
