Under Review
Bug report - Audio.Output plays at wrong speed over Bluetooth headphones (speaker is correct) – fēnix 8, SDK 9.3.0
**Title:** Audio.Output plays at wrong speed over Bluetooth headphones (speaker is correct) – fēnix 8, SDK 9.3.0
**Device:** fēnix 8 51mm AMOLED (part no. 006-B4536-00), firmware 23.40
**SDK:** Connect IQ 9.3.0 (2026-10-20), app type watch-app, minApiLevel 6.0.3, permission AudioOutput
**Headphones:** Bluetooth headphones paired to the watch (native music playback through them works fine)
**Summary**
Audio played with `Toybox.Audio.Output.play()` from a `StreamingAudioSource` sounds correct on the watch speaker, but plays at the wrong speed when Bluetooth headphones are connected. The headphone path seems to ignore the `AudioFormat` `:frequency` and use a fixed rate.
**Steps to reproduce**
1. Create a `StreamingAudioSource` subclass with e.g.
`{:format => {:containerFormat => Audio.CONTAINER_OGG, :codec => Audio.CODEC_OPUS, :frequency => Audio.FREQ_24_KHZ, :channels => Audio.CHANNEL_MONO}, :bufferSize => 32768}`
2. Fill it with a valid Ogg Opus file (speech, mono, 24 kHz, 16 kbit/s, made with ffmpeg/libopus) via `append()`, then `end()`, and call `Audio.Output.play(source, null)`.
3. Listen on the watch speaker: correct speed and pitch.
4. Connect Bluetooth headphones and play again.
**Expected:** Same speed and pitch in the headphones as on the speaker.
**Actual:**
| Format given to the source | Speaker | Bluetooth headphones |
| OGG/OPUS, 24 kHz, mono | correct | slow, low and "vibrating"/distorted |
| OGG/OPUS, 16 kHz, mono | correct | slow and distorted |
| OGG/OPUS, 24 kHz, stereo | correct | slow and distorted |
| WAV/LPCM 16-bit, 8 kHz, mono | (not tested) | far too fast, choppy |
| WAV/LPCM 16-bit, 16 kHz, mono | (not tested) | too fast, choppy |
Opus (which decodes at 48 kHz internally) comes out too slow, and LPCM at 8 and 16 kHz comes out too fast. That points to the Bluetooth path playing the samples at one fixed rate somewhere between 16 and 48 kHz, regardless of the declared format.
Also: when the headphones are disconnected during playback, the output switches to the speaker, but the distorted audio continues for about 0.5 s before it becomes correct.
**Possibly related:** Each `append()` made while the source is playing gives a short audible click/dropout in the audio being played at that moment, even when the appended data begins on a clean Ogg page boundary. Appending everything before `play()` avoids it.
Happy to share a minimal test app and the test audio files.
