Acknowledged
documentation improvement request: onSwipe is only left/right or up/down on certain devices
I'm not sure if it's a bug in the physical device as well (because I don't have one) and the simulator reproduces it correctly (In which case it would be a good idea to add this to the documentation) or it's a bug in the simulator.
InputDelegate.onSwipe is only triggered for left-right swipes but not for up-down swipes. SDK: 6.4.2. Tested with the Input sample.
  • That's the same as the real vivoactive.  The va-hr is similar, but the same screen was used, turned 90 degress (no left/right there)
    Also, both of these have 9 "touch regions",  with a a tap or hold, you only see 9 different locations.  You won't see this in the sim.
    .On the va3, a swipe to the right is seen as omBack, as there is no back button.
