Took a lot of testing to obtain the following findings.
The issue affects at least the following devices:
| 006-B4315-00 (fr965) | |
| 006-B3224-00 (vivoactive4s) | |
| 006-B4313-00 (epix2pro47mm) |
Important notes:
1. In the simulator all tests work without issue.
2. Through the Music Player > Sync Menu, the watch starts looking for WIFI, then shows the menu. From here, all tests work without issue.
3. Through the Music Player > Library Menu, the watch uses the BLE to perform webrequests. From here, BLE_HOST_TIMEOUT is returned under the following conditions.
The following examples are giving BLE_HOST_TIMEOUT:
var options = {
:method => Communications.HTTP_REQUEST_METHOD_GET,
:headers => {
"Content-Type" => Communications.REQUEST_CONTENT_TYPE_JSON,
"Accept" => "application/json",
:responseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_JSON,
Communications.makeWebRequest(url, null, options, method(:onResponse));
Communications.makeWebRequest(url, {}, options, method(:onResponse));
The following example does result in an expected response from the server without error:
Communications.makeWebRequest(url, {"test"=>"test"}, options, method(:onResponse));
So, adding a single parameter to the request makes it work.
But adding any custom header to the options dictionary and all results in the BLE_HOST_TIMEOUT:
var options = {
:headers => {
"device" => "Watch,
Due to the difference in behaviour between WIFI and BLE connected states, I assume this is a bug either in the watch firmware, or the Android application that is forwarding these requests. Is this indeed a bug? Is there a workaround? Looking forward to receive your response!
