Complete
Bug. Instinct 2x. ConnectIQ memory allocation. FW 14.12
The Instinct 2X only makes 96kB of memory available to each Connect IQ app.That means that applications or some of the features of the applications that need the 2.x version of Garmin Connect IQ that need to allocate 128kB of memory to each application, do not work.
It also happens that as a developer, I have seen applications that need more than those 96kb limit during the running period, crashing eventually with Out Of Memory errors and even crashing the watch.
Having this limit in Firmware does not have any sense at all and that 96kb limit should be removed or increased at least at 128kb. I report this as a bug because that 96kb limitation breaks compatability, does not have sense and should not exist.
I mean, we are crashing prematurely because of that limit and this watch is pretty new with the same amount of RAM as the FR935, which does not have this limit. So, at the end, this is a bad experience to the user and bad for Garmin then. It is just to correct that memory limit. This bug should be fixed.
Thanks
Parents
  • Thanks for the answer Jim but the FR935 does not have either that 96kb and is a lot older.  I was speaking only about CIQ 2. I know, as a developer, the 96kb limit is wrong here. It should be increased to 128kb for this watch. Is just only that.
Comment
Children
No Data
