The Instinct 2X only makes 96kB of memory available to each Connect IQ app.That means that applications or some of the features of the applications that need the 2.x version of Garmin Connect IQ that need to allocate 128kB of memory to each application, do not work.
It also happens that as a developer, I have seen applications that need more than those 96kb limit during the running period, crashing eventually with Out Of Memory errors and even crashing the watch.
Having this limit in Firmware does not have any sense at all and that 96kb limit should be removed or increased at least at 128kb. I report this as a bug because that 96kb limitation breaks compatability, does not have sense and should not exist.
I mean, we are crashing prematurely because of that limit and this watch is pretty new with the same amount of RAM as the FR935, which does not have this limit. So, at the end, this is a bad experience to the user and bad for Garmin then. It is just to correct that memory limit. This bug should be fixed.
Thanks
Kyle.ConnectIQ
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
Kyle.ConnectIQ
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
