Acknowledged
Bug in Simulator 7.2.1 with Float vs Long comparisons
In the following:
    var l = 1L;
    var f = 1.0f;
    System.println(f==l); // false in 7.2.1, true in 7.2.0 and earlier
    System.println(l==f); // false in 7.2.1, true in 7.2.0 and earlier
    System.println(1.0f==1L); // false in 7.2.1 with optimization off, true with optimization on
Essentially, when the 7.2.1 simulator evaluates 1.0f==1L it returns false. All previous simulators return true.
Note that the optimizer also thinks the result is true.
I've not tried on a device yet, but from past experiments I'm pretty sure that all the watches I've used report true.
If this is something that's going to change, or that devices are inconsistent about, the type checker should issue a warning for long vs float comparisons, and the optimizer shouldn't optimize constant comparisons (especially not to the wrong value!). But my guess is that this is just a bug in the simulator.
Parents
  • 7.3.0 has the same issue. It's also more extensive than I initially thought. For both 7.2.1 and 7.3.0, it also affects Long vs Char, Float vs Char and Double vs Char.
    ie
    var num as Number = 42;
    var lng as Long = 42L;
    var flt as Float = 42F;
    var dbl as Double = 42D;
    var chr as Char = '*';
    lng == chr; // false in 7.2.1 and later, for older devices
    flt == chr; // false in 7.2.1 and later, for older devices
    dbl == chr; // false in 7.2.1 and later, for older devices
    // all other pairwise comparisons are true
    > This might be related to the fact, that 7.2.1 has the following line in the release notes
    Yes, I think that's it. For devices like fr955, all the comparisons still return true. But eg fenix5xplus is apparently an "older" device.
    > But ofc that wouldn't help for ... or in situations where the type isn't certain.
    If it followed its existing behavior for such things, it actually would:
      var q as Number | Boolean = false;
      var t as Boolean = q == false;
    Gives me a warning: "Attempting to perform operation 'eq' with invalid types '$.Toybox.Lang.Number' and '$.Toybox.Lang.Boolean'.". And yes, I filed a bug against this particular warning, because it's a perfectly valid thing to check: q is either a Number or a Boolean, and I want to know if it contains the value "false".
    But the point is that here, the type checker doesn't know whether they're both Boolean, so it issues a warning. It should obviously do the same thing for the invalid comparisons above even if the types aren't certain. ie, if one argument might be a Float, and the other might be a Long, (and the type checker is in a sufficiently strict mode) it should warn.
Comment
    ie
Children
