Complete
WERETECH-10739
Fixed
Bug in compilator , with String.equals and utf8 symbol
Function Always show false, but symbol the same.
var dTExt = "";
Toybox.System.println( ((dTExt.equals("") ))  );
Parents
  • Sorry i give you wrong start data
    Its old bug, foget how it work
    //code 60106  ,  code60107  - 0ff
    allways show true, but symbol not equal , tested now on 3.2.5
    var dTExt = "";
    if i add "1" to both text - function show false
    //60106  - on 60107  - 0ff
    var dTExt = "1";
    Toybox.System.println( ((dTExt.equals("1") )) );
    thats how i fix this isue
Comment
    var dTExt = "";
    var dTExt = "1";
Children
  • You equal  only 1 symbol
    try diferent:
    1: 
    2: 
    code of symbols  and 
    This bug  i was get when redraw new icon from font, and check new with old text
  • I can't reproduce. Here is the source for my test app.
    using Toybox.Application;
    using Toybox.WatchUi;
    using Toybox.System;
    function as_hex_bytes(s) {
    	var r = [];
    	var a = s.toUtf8Array();
    	for (var i = 0; i < a.size(); ++i) {
    		r.add("\\x" + a[i].format("%X"));
    	return r;
    function as_code_points(s) {
    	var r = [];
    	var a = s.toCharArray();
    		r.add(a[i].toNumber());
    	return r;
    function as_unicode_escapes(s) {
    	var r = [];
    		r.add("\\u" + a[i].toNumber().format("%X"));
    	return r;
    class ForumTestApp extends Application.AppBase {
        function initialize() {
            AppBase.initialize();
    		var s = "";
    		// var s = "\uEACA";
    		System.println(s);
    		System.println(as_hex_bytes(s));
    		System.println(as_code_points(s));
    		System.println(as_unicode_escapes(s));
    		System.println(s.equals(s));
    		System.println(s.equals(""));
    		System.println("".equals(s));
    		System.println(s.equals("\uEACA"));
    		System.println("\uEACA".equals(s));
        function getInitialView() {
            return [ new WatchUi.View() ];
    The output in the eclipse console is:
    [\xEE, \xAB, \x8A]
    [60106]
    [\uEACA]
    true
    true
    true
    true
    true
