Acknowledged
over 1 year ago
Bug: Enduro 2 will not compile on 5.0.0
When selecting 5.0.0 - System 7 under Minimum Supported API Level in the manifest.xml file, during Monkey C: Export Project, a version for the Enduro 2 will not be created. (of course with product "fenix 7x/tactix 7/quatix 7/enduro 2" selected.)
After selecting 4.2.0 - System 6, it does work as expected.
Currently tested on sdk 7.1.1.
Kind regards
Parents
  • The export process should warn you if part numbers were not exported, unless something has changed recently (which would be a bug imo).
    I do find it annoying how certain models are grouped together in ciq which aren't even grouped together in the store (as in this example), and sometimes there are significant differences between the grouped models.
    For example, the CIQ edge_1000 device groups together two distinct models: Edge 1000 and Edge 1000 Explore. The former device supports power meters, the latter does not. This means that if you wanted to release an app which requires power meter support, and you want to support Edge 1000, you also have to support Edge 1000 Explore, even though the latter device would not be appropriate for your app.
Comment
Children
No Data
