In https://developer.garmin.com/connect-iq/api-docs/Toybox/Position.html#enableLocationEvents-instance_function there are typos:
if (Position has :CONFIGURATION_GPS_GLONASS_GALILEO_BEIDOU_L1_L5) &&
(Position.hasConfigurationSupport(Position.CONFIGURATION_GPS_GLONASS_GALILEO_BEIDOU_L1_L5)) {
options[:configuration] = Position.CONFIGURATION_GPS_GLONASS_GALILEO_BEIDOU_L1_L5;
} else if (Position has :CONFIGURATION_GPS_GLONASS_GALILEO_BEIDOU_L1) &&
(Position.hasConfigurationSupport(Position.CONFIGURATION_GPS_GLONASS_GALILEO_BEIDOU_L1)) {
options[:configuration] = Position.CONFIGURATION_GPS_GLONASS_GALILEO_BEIDOU_L1;
} else if (Position has :CONFIGURATION_GPS) &&
(Position.hasConfigurationSupport(Position.CONFIGURATION_GPS)) {
options[:configuration] = Position.CONFIGURATION_GPS;
all 3 if have an "extra" zombie parentheses around the &&:
instead of just:
update: and BTW the example code (with typecheck: 3, but I guess it doesn't matter in this case) gives warnings:
options[:constellations] = [ Position.CONSTELLATION_GPS, Position.CONSTELLATION_GLONASS ];
enduro3: '$.Toybox.Position.CONSTELLATION_GPS' is deprecated.
enduro3: '$.Toybox.Position.CONSTELLATION_GLONASS' is deprecated.
