Acknowledged
CIQQA-3954
BUG: Connect IQ Data Fields Not Persisting on Navigation Screens
Hello,
I'm experiencing a persistent issue with Connect IQ data fields on my Garmin Fenix 7 Pro specifically related to navigation screens.
Problem Description:
When I add a Connect IQ data field to a navigation screen, it appears correctly during configuration. However, when I start a new activity with navigation enabled, the Connect IQ field is automatically replaced by the default Timer field.
Steps to Reproduce:
  1. Go to Navigation Settings → Data Screens
  2. Add an additional navigation screen
  3. Add a Connect IQ data field to this screen (any Connect IQ field)
  4. Save and exit
  5. Start a new activity with navigation enabled
  6. Result: The Connect IQ field has been replaced by Timer
What Works:
  • Connect IQ fields work perfectly on regular activity screens (non-navigation)
  • Native Garmin data fields persist correctly on navigation screens
  • The configuration appears saved until the activity is restarted (if go to navigation settings during an activity)
What I've Tried:
  • Multiple different Connect IQ data fields from the store
  • Developing my own custom data field using Connect IQ SDK 5.2 with API Level 5.2
  • Latest firmware version on Fenix 7 Pro
  • Removing and re-adding the fields
  • Different activity profiles
Device Information:
  • Model: Fenix 7 Pro
  • Firmware version: 25.11
Question:
Is this a known bug? Are navigation screens supposed to support Connect IQ data fields, or is this a limitation? It seems inconsistent that native fields persist but Connect IQ fields don't.
Any workaround or fix would be greatly appreciated.
Thank you!
Parents
  • I think it's different on fr965. When I enter from Run as per your steps, or from Navigate "app" there's no way to edit the fields. Only as I found it and posted before, from the system menu. Not sure why or if this is another bug.
    Maybe if I go this way: Run > Run Settings > Data screens > Add new > Map ?
    Can you post a screenshot how this page / screen looks like?
Comment
Children
No Data
