Using (Edit Persistent Storage > Application Properties)
Editing some settings that are backed by <setting> <group> in the simulator.
Not all values are updated. There doesn't seem to be an obvious pattern as to which settings will apply, and which never get applied / never change in <Application Settings?
Example:
1. Set all boolean toggles to true - all looks good. The toggles agree with the underlying settings properties, code reads same values:
2. Set all boolean toggles to FALSE . Some of the underlying settings properties have not been updated. The running code confirms some settings have not been written:
Note: to ensure UI values update immediately: Hit Save on App Settings Editor; Ensure Simulator DisplayMode is High Power; Hit Refesh on the Memory Window
The source code for the fully working watchface exhibiting this issue can be found here:
https://github.com/blueacorn/Infocal
Thanks
