import Toybox.Activity;
import Toybox.Lang;
import Toybox.Position;
function onPosition(info as Position.Info) as Void {
var ai = Activity.getActivityInfo();
function initLocationEvents(config as Number) as Void {
Position.enableLocationEvents(Position.LOCATION_CONTINUOUS, new Lang.Method($, :onPosition) as Method(loc as $.Toybox.Position.Info) as Void);
fr955: 'Info' is ambiguious and exists in multiple imported modules [$.Toybox.Position.Info, $.Toybox.Activity.Info].
My code originally was:
Position.enableLocationEvents(Position.LOCATION_CONTINUOUS, method(:onPosition));
but it doesn't work if onPosition is global. Then it was:
Position.enableLocationEvents(Position.LOCATION_CONTINUOUS, new Method($, :onPosition));
but the strict typechecker doesn't like that, so then it was:
Position.enableLocationEvents(Position.LOCATION_CONTINUOUS, new Method($, :onPosition) as Method(loc as Position.Info) as Void);
Which should work, but then new Method only works with -O1 or above (fair enough) so then:
Position.enableLocationEvents(Position.LOCATION_CONTINUOUS, new Lang.Method($, :onPosition) as Method(loc as Position.Info) as Void);
Now this should work. However there's still the next BUG in the strict type checker/compiler: this gives the following warning:
So I said, ok, what not I will do to make the type checker happy?
However even this gives the same warning. This is clearly a bug in that the type checker throws away the "Position" or whatever is before Info.
Now this is funny, because this should work, period. However this is happening not because my code has another Info class, it's the SDK that has multiple Info classes... so at least the compiler should work with the SDK...
flocsy🤠
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
flocsy🤠
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
