Complete
WERETECH-8574
Bug: Activity.Info.elapsedDistance is way off if playback a .fit file using simulator 3.1.6
Activity.Info.elapsedDistance is way off not only due to lat/lon = [0.0, 0.0]
https://forums.garmin.com/developer/connect-iq/i/bug-reports/initial-values-lat-lon-0-0-if-replaying-a-fit-in-simulator
but rather it seems there are more bugs in the sim.
info.elapsedDistance should be the sum of the distances between the recorded position points lat/lon. So I've calculated the sum of this distance increments and compared it to the value of info.elapsedDistance. I've only used a fast and easy formula to calculate the distances between 2 position points without any smoothing or interpolation. Thus my calculated elapsed distance may differ somewhat to info.elapsedDistance.
By replaying a .fit I get the following values
My sum of distance increments = 125.82m
Activity.info.elapsedDistance = 194.69m
This is a difference of >54% which is well way off.
In the .tcx file of the .fit for the same lat/lon there is stored the value
<DistanceMeters>123.29000091552734</DistanceMeters>
If I don't use the "Playback File" option but instead use the option "Simulate Data" I get this values
My sum of distance increments = 124.67m
Activity.info.elapsedDistance = 129.09m
This is a difference 3.5% that seems to be reasonable to me.
Since "Simulate Data" generates random values the distances are different to the "Playback File" values.
Parents
  • Thanks Jim, your hint is very helpful for me. Now I know that I'm the only one with this issue.
    I'am pretty sure that the .fit is correct.
    In the discussion forum
    forums.garmin.com/.../replaying-fit-file
    I've already posted a graph from
    BaseCamp distance = 0 - 0.21km (current speed ~ 7 ... 9 km/h)
    Garmin Connect distance = 0 - 2km (pace ~ 8:30 ... 7:30 min/km -> Speed ~ 7 ... 8 km/h)
    Simulator distance = 0 - 0.2km (my calculated current speed = (d2-d1)/(t2-t1) ~ 10 ... 15 km/h)
    Since (t2-t1) = 1 for 1s recording, the speed is simply (d2-d1).
    I always start my activities after at least 30s continuous GPS fix (green circle) and as you can see in the above graphs there is no GPS gap.
    As I've shown above the .tcx distance is also OK.
    Now I've another suspicion that sounds reliable for me. The difference of info.elapsedDistance is about 54% and this is pretty near of the difference mi/km = 1609m/1000m=1.6 resp. 60%. My .fit is recorded in metric unit system and info.elapsedDistance is always in m as described in the API documentation. If I use statute unit system, the sim must convert from mi to m. I've used both in the sim but not seen any difference between metric and statute. For testing I've used miles = info.elapsedDistance / 1.6 and this looks much better. But I'm not sure that this is the reason.
    Also lat/lon [0,0] I can reproduce regardless of the .fit . If I first start the timer in the sim and subsequently start playback file info.elapsedDistance is a huge value as is shown in the table in the discussion forum.
Comment
Children
