Acknowledged
bug: activity data simulation doesn't work on Mac
None of the watch buttons or the buttons in Simulation > Activity Data window trigger any of the callback functions on a DataField. The same code with the same SDK version did work in Linux, so this seems to be a bug in the Mac implementation of the simulator.
SDK 4.1.7, MacOS: 13.1
I found some similar issues but none is exactly the same:
https://forums.garmin.com/developer/connect-iq/i/bug-reports/ciq-simulator-time-simulation-does-not-work-on-mac
https://forums.garmin.com/developer/connect-iq/i/bug-reports/sdk-4-1-1-simulator---activity-data-simulation-do-not-support-button-press
https://forums.garmin.com/developer/connect-iq/i/bug-reports/simulator-in-sdk-4-0-6---removed-support-for-activity-simulation-for-widgets-and-watch-faces
  • I have seen cases where the sys.nfm (in the temp folder) file gets corrupted if you force kill the simulator. You can hack around the issue by manually deleting that file or blowing away the temp folder.
  • Yes it work now. I don't know what happened, because at least twice (a month ago and a few days ago) it didn't work. Maybe the simulator was stuck.
  • I'm on a MacbookPro right now and I'm seeing no such problems with either the 4.1.7 or 4.2.1 SDK. Here is the debug output from my test app.. the X vs Y values are the timerTime vs elapsedTime values of the Activity.Info object.
    I'm able to use both the device buttons in the simulated device as well as the buttons in the Activity Data menu.
    Background: AppBase.initialize
    Background: AppBase.onStart
    Background: AppBase.getServiceDelegate
    Background: AppBase.onAppInstall
    AppBase.initialize
    AppBase.onStart
    AppBase.getInitialView
    View.initialize
    View.onLayout
    View.onShow
    0 vs 0
    0 vs 0
    0 vs 0
    0 vs 0
    0 vs 0
    0 vs 0
    0 vs 0
    0 vs 0
    0 vs 0
    0 vs 0
    0 vs 0
    View.onTimerStart
    48 vs 48
    1071 vs 1071
    2070 vs 2070
    View.onTimerStop
    2644 vs 3071
    2644 vs 4071
    2644 vs 5070
    2644 vs 6070
    View.onTimerLap
    2644 vs 3144
    2644 vs 4143
    2644 vs 5144
    2644 vs 6143
    2644 vs 7144
    2644 vs 8144
    2644 vs 9144
    2644 vs 10144
    2644 vs 11119
    View.onTimerStart
    3571 vs 12143
    4572 vs 13144
    5572 vs 14144
    6571 vs 15143
    7572 vs 16144
    Background: AppBase.onStop
    View.onTimerPause
    7647 vs 17145
    View.onTimerResume
    View.onTimerLap
    8572 vs 18144
    9572 vs 19144
    View.onWorkoutStepComplete
    10572 vs 20144
    View.onNextMultisportLeg
    11546 vs 21118
    12572 vs 22144
    13572 vs 23144
    14572 vs 24144
    View.onTimerStop
    14572 vs 25144
    14572 vs 26144
    14572 vs 27144
    14572 vs 28118
    14572 vs 29144
    AppBase.onStop
