Under Review
Boolean property in settings group with default value true can't be changed in simulator
Hi,
a property with a deault value true can't be changed in simulators settings editor if it in a settings group.
With default false all is working correct. It seems this is only a simulator problem. The smartphone app works correct.
I have read the thread:
https://forums.garmin.com/developer/connect-iq/i/bug-reports/bug-boolean-properties-with-default-value-true-can-t-be-changed-in-simulator
It seams to be fixed for a general property with default value true, but not if the settings to change this property in a settings group.
Latest SDK 8.3.0 is used
