Complete
over 6 years ago
Bogus Circular Dependency error
I am getting a bogus circular depency error. My app has a dependency on my barrel. The code of my barrel is shown below. My barrel has a global variable initialized to an instance of InitClass, which triggers the execution of the corresponding constructor when the module is first loaded. This constructor registers a sensorData listener callback. The call to Sensor.registerSensorDataListener() is what is causing the circular dependency error. This seems to be a problem with referencing that particular method and not the entire Sensor module. I know this because if I replace the call to Sensor.registerSensorDataListener() with the following line of code
    System.println(Sensor.SENSOR_BIKEPOWER);
Then the code compiles fine and I do not get the circular dependency error. What I think may be happening is that the system is treating the "options" parameter as dependency that the Sensor module is having on my barrel, which is clearly incorrect.
module MyBarrel
    (:MySubModule)
    module MySubModule
        using Toybox.Sensor;
        var options = {
            :period => 1,
            :accelerometer => {
                :enabled => true,
                :sampleRate => 25,
                :includePitch => true
            :heartBeatIntervals => {
                :enabled => false
        var init = new InitClass();
        class InitClass
            function initialize()
                Sensor.registerSensorDataListener(method(:callback), options);
            function callback(sensorData)
Parents
  • I don't think this is a bogus error. The cycle detection code detects actual cycles, not possible cycles.
    The parameter passed to `registerSensorDataListener` is a `Lang.Method` which keeps a reference to an object and a function to call on that object. That means the Sensor module has a reference to the `MyBarrel.MySubModule.init` object. I'm not sure where the other references are, but they are there.
    The easiest way to avoid something like this is to add methods to your module to register/unregister callbacks. Something like this:
    module MyModule
        function registerSensorDataListener() {
            var options = {};
            Sensor.registerSensorDataListener(method(:onSensorDataCallback), options);
        function unregisterSensorDataListener() {
            Sensor.unregisterSensorDataListener();
        function onSensorDataCallback() {
    It will require that the module/barrel user call `registerSensorDataListener` and `unregisterSensorDataListener` (typically from `App.onStart` and App.onStop` or `View.onShow` and `View.onHide`), but it should eliminate the cycle in cases where your application starts and exits normally.
Comment
    module MyModule
            var options = {};
Children
No Data
