Ticket Created
JAZZ-2957
Transferred
BLE related device crash
In my Battery State app, I'm also attempting to read battery info from nearby BLE heart rate monitors (since AntPlus API does not support heart rate devices). This itself works, I'm able to pair and read the battery information ok.
However there is something wrong with stopping and starting the app quickly. When done quickly enough, I get device crash. This can be repeated very easily on my Edge 530. I'm not fully certain, but based on my debug printfs, crash seems to come sometime after I have received onProfileRegister callback.
I have tried to unpair the BLE devices onStop of the app, without making any change. I also looked into unregistering my BLE UUIDs if that would make difference, but I didn't find a way for it.
I paste the log info here:
"unit_id":"3305309131",
"product_name":"Edge 530",
"software_part_number":"006-B3121-00",
"ms_since_epoch":1587128451000,
"system_version":"5.31",
"build_type":"PRODUCTION",
"backtrace":"BTF main - Error type ( 0 ) File( ..\\..\\..\\UNI\\uni_cnvt.c ) Line( 2634 )",
"error_cause":"Assert",
"proprietary_info":{
"Commit ID":"85668e0bdbda79c6fd3aeae4f574f911741faecd",
"Time":"2020-4-17 15:0:51",
"Ram Dump":"N/A",
"ESht PC":"0x00000000",
"ESht SP":"0x00000000",
"Project Specific":"0x00000000",
"Fatal":"NO",
"Task ID":"61E96128",
"Task Name":"BTF main",
"File Name":"..\\..\\..\\UNI\\uni_cnvt.c",
"Line Number":"2634",
"Message":"2634"
"ms_since_epoch":1587128517000,
"backtrace":"HWM GFS main - Error type ( 0 ) File( ..\\..\\..\\JEFF\\jeff_fat.c ) Line( 479 )",
"Time":"2020-4-17 15:1:57",
"Ram Dump":"N/A",
"Fatal":"NO",
"Task ID":"61FFBC00",
"Task Name":"HWM GFS main",
"File Name":"..\\..\\..\\JEFF\\jeff_fat.c",
"Line Number":"479",
"Message":"479"
"ms_since_epoch":1587128519000,
"Time":"2020-4-17 15:1:59",
"Ram Dump":"N/A",
"Fatal":"NO",
"Message":"479"
"Ram Dump":"N/A",
"Fatal":"NO",
"Message":"479"
"Ram Dump":"N/A",
"Fatal":"NO",
"Message":"479"
"ms_since_epoch":1587128521000,
"backtrace":"SYC main - Error type ( 0 ) File( ..\\..\\..\\CDP_REC_CORE\\cdp_main.c ) Line( 2116 )",
"Time":"2020-4-17 15:2:1",
"Ram Dump":"N/A",
"Fatal":"NO",
"Task ID":"62266220",
"Task Name":"SYC main",
"File Name":"..\\..\\..\\CDP_REC_CORE\\cdp_main.c",
"Line Number":"2116",
"Message":"2116"
"backtrace":"SYC main - Error type ( 0 ) File( ..\\..\\..\\CDP_REC_CORE\\cdp_main.c ) Line( 2055 )",
"Ram Dump":"N/A",
"Fatal":"NO",
"Line Number":"2055",
"Message":"2055"
"ms_since_epoch":1587128491000,
"backtrace":"
Function Address: 0x601878E4
Call Address at Function: 0x60187944
Function Address: 0x6018490C
Call Address at Function: 0x60184930
Function Address: 0x6044A174
Call Address at Function: 0x6044A196
Function Address: 0x60A2EE58
Call Address at Function: 0x60A2F368
Function Address: 0x6029F6DC
Call Address at Function: 0x6029F6EA
Function Address: 0x60182CE8
Call Address at Function: 0x60182CFC
Function Address: 0x6044E1CC
Call Address at Function: 0x6044E2AE
Function Address: 0x60762CCC
Call Address at Function: 0x60762CEC
"error_cause":"RTL Trap",
"Time":"2020-4-17 15:1:31",
"Ram Dump":"1",
"ESht PC":"0x60307141",
"ESht SP":"0x621E2798",
"Project Specific":"0x621E2798",
"CDP_LOG":"605F087D,6045A9F9,605D7681,60211D3D,601CCA11,60211D3D,601CCA11,60211D3D,601CCA11,60211D3D,601CCA11,60211D3D,601CCA11,",
"RTL Error Number":"6E5D8024",
"Error Message":"00000006,00000000,00000000,00000000,00000065,61E921A4,0000000C,00000000,00000000,00000001,00000000,D0512EB6,0000EBAD,62259AB8,6018472F,60187944,200F003F",
"Task Name":"wscm_ble_main",
"Saved SP":"62259AB8",
"Saved LR":"6018472F",
"Saved PC":"60187944",
"R[0]":"00000006",
"R[1]":"00000000",
"R[2]":"00000000",
"R[3]":"00000000",
"R[4]":"00000065",
"R[5]":"61E921A4",
"R[6]":"0000000C",
"R[7]":"00000000",
"R[8]":"00000000",
"R[9]":"00000001",
"R[10]":"00000000",
"R[11]":"D0512EB6",
"R[12]":"0000EBAD",
"R[13]":"62259AB8",
"R[14]":"6018472F",
"R[15]":"60187944",
"cpsr":"200F003F"
"ms_since_epoch":1587128533000,
"backtrace":"BTF main - Error type ( 0 ) File( ..\\..\\..\\BTF\\btf_wifi_setup.c ) Line( 721 )",
"Time":"2020-4-17 15:2:13",
"Ram Dump":"N/A",
"Fatal":"NO",
"File Name":"..\\..\\..\\BTF\\btf_wifi_setup.c",
"Line Number":"721",
"Message":"721"
Parents
  • what I've seen is like your #1.
    One thing I've done is while scanning, I not only look for the proper advertisement, but also check the rssi, as I've seen if the signal is too low, pairing may take much longer if it occurs at all, opening the window much more.
Comment
Children
No Data
