Toybox.System.Stats.batteryInDays does not return float values on F7 Pro. The correct float values are returned by the sim. While batteryInDays returns a type float, the value returned is always an int. No non int values are returned. When there is not more than a day left of battery the value returned is 0 or 1.The battery in days is returned correctly on the sim (can be a float between 0 and 1). Which does not make is possible to display hours remaining, even though the type should support it, and the developer would expect it.
Device info:
- Fenix 7 Pro MP unit
- FW: 20.19
- CIQ 7.4.3
