Acknowledged
CIQQA-3534
battery saving concerning the backlight illumination brightness of the display for solar models
Hi there,
I have the following idea / feature request for solar watch models:
Use the solar input percentage as a a dimming lever for the backlight display illumination.
Meaning:
the higher the solar input level, the lower should be the display illumination brightness
example:
the user has set the display to "Backlight on Gestures" and the display brightness to say 50%.
now the user is outside in the sun and flicking his wrist which activates the display backlight.
here my above request would not trigger the display backlight when the incoming solar input data
is high enough (this value would have to be determined).
and if the user is in various light settings the display backlight brightness could be adjusted
according the solar input data.
many thanxx for a positive consideration....
greetz
oliver
