Acknowledged
Battery lifetime AOD mode AMOLED
Hi,
I've found that battery life doesn't change much when there are no pixels on or 10% of the pixels are on in AOD mode. This means that as soon as AOD is switched on, the battery life drops from 10 to 3 days even if there are no pixels on in AOD mode.
Apparently, a switched-on display requires a lot of power, regardless of the number of lit pixels. I tested on a Venu2 plus. Is this also the case with other AMOLED devices, or is it a firmware problem?
