Ticket Created
HESPER-3016
Transferred
Back missing for menu in widget?
In the App version of my program, I see a back button/icon for menus on my (real) 1030 (using SDK 3.1.9.
In the Widget version of my program, I see an X (not a back button/icon). That doesn't behave the same way either.
I'm pretty sure this didn't happen with older versions.
What's up with that?
  • I have the same program compiled as a widget and an app.
    It's the same code.
    The app works properly. The widget is garbage.
    The two worked the same before.
  • The UI shouldn't have changed.
    The UI is different between the widget and the app on the 1030. Which doesn't make sense.
    The menu is popped but it's no a call to the "back" handler (or so it seems).
  • I built the ProgressBar sample and installed it on my edge1030 (fw9.50). When I press the menu button, I'm shown a menu with an X in the lower left corner as you've described, but as far as I can tell, pressing the X behaves like it should (the menu is popped). Can you describe further what you mean when you say "it doesn't behave the same way either"? I built and ran the same app on an edge1000 and it showed the back arrow as expected. It seems that there has been a change to the UI on the edge1030.
