Ticket Created
AppBase.getSettingsView does not work for Venu 2
When getSettingsView is implemented in a data field application, it should be accessed by holding the Back/Menu button under "ConnectIQ Fields" menu item, but for Venu 2 this item is not displayed.
I created a simple application that implements the getSettingsView method and can be tested by following these steps:
1. Download the data field: https://github.com/maca88/SmartBikeLights/blob/test/venu2-settings/Source/GradeDataField/build/venu2/GradeDataField.prg
2. Copy the prg file into folder "/GARMIN/APPS" on Venu 2
3. Add the grade data field (GradeDataFieldApp) on an activity
4. Go back to the main screen and then go back to the activity (this step is required for forerunner 245 to make "ConnectIQ Fields" menu item visible).
5. Hold the Back/Menu button and there should be a "ConnectIQ Fields" menu item, but is isn't, only "Stop Live Tracking", "Navigation", "Bike Settings" and the settings wheel are displayed
Here is the discussion with the user that tested it: https://forums.garmin.com/developer/connect-iq/f/showcase/248492/smart-bike-lights-data-field-bike-lights-control-widget/1436786#1436786
For reference, when testing the above data field in a forerunner 245, the settings can be accessed within "ConnectIQ Fields" item menu after holding the "Up" button.
  • So it IS supposed to be accessible during activity?
    I made simple settings screen to disable/reset my data field on my Vivoactive 4, it works great in simulator using "Trigger app settings", but it's not accessible on the watch itself during activity.
    Only way to access it is to start an activity, on the "wait for GPS" screen I can swipe up and the "conectIQ field" menu item is there. But this doesn't help me with resetting the data field during activity. :(
  • Hi Kendal,
    If this is by design then it would make sense to document it in the API documentation of getSettingsView method, as currently it does not mention that for Venu 2 the method works only for CIQ watch face applications:
    I would suggest to add a note below the "Supported Devices" list that contains all devices where the method is only applicable to watch faces. Example:
    NOTE: For the following devices:
    Venu 2
    this function is only applicable to watch faces.
    Also the Venu 2 simulator should be updated to reflect that as currently the "Trigger App Settings" is enabled for data field applications.
    Does this limitation apply to all Venu devices (e.g. Venu, Venu 2S, Venu Sq, Venu Sq 2, ...)?
  • Hi. I just checked on the update about this ticket. This is by design for Venu 2.
  • Is there any status update about this ticket? Thanks in advance.
