Ticket Created
CIQQA-1132, RENU-12970
App settings' titles not correctly localized
The prompt and the title should be retrieved from the corresponding resources-lang/string.xml,eg resources-eng/strings.xml, but I found it only will get the string from the default string.xml. Please inspect it
This issue appears in fitcontribution as well, which results in a lot Chinese users see English connect IQ field names with some in Chinese, you can check it in the comment area.
SDK version:4.1.2
VSC:1.0.5
