Acknowledged
CIQQA-4196
API docs: nativeNum option missing for DataField.createField()
In the API docs, the nativeNum option is documented for ActivityRecording.Session.createField(), but not DataField.createField(), although I believe it's actually available for both functions. (Since I have an old CIQ data field which uses nativeNum, and this use case has been heavily discussed over the years.)
https://developer.garmin.com/connect-iq/api-docs/Toybox/ActivityRecording/Session.html#createField-instance_function
https://developer.garmin.com/connect-iq/api-docs/Toybox/WatchUi/DataField.html#createField-instance_function
Parents
  • It does do something.
    It allows CIQ device apps / data fields to override native fields in 3rd-party apps / sites like Strava.
    Yes it's well known that Connect will ignore nativeNum, but the same cannot be said of all 3rd party sites.
    There's years of discussion on the forums about this. I've written apps that take advantage of this, and obviously Stryd is the most prominent example of this use case. (Strava will use Stryd power if you disable the recording of native power. You should know this very well, since I've mentioned this a million times in threads that you have either started or have been a part of.)
    Go ahead and look at the FIT files that are created when you use the Stryd data field on a run.
    Note what I wrote in the bug report:
    "(Since I have an old CIQ data field which uses nativeNum, and this use case has been heavily discussed over the years.)"
    You think that devs use nativeNum for absolutely no reason?
Comment
Children
No Data
